Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 12-15-2008, 09:33 PM   #1
JiC
JiC is an unknown quantity at this point
MDX and AutoIt with COM
Just upgraded to the new version of MDX with COM support. Awesome! Got Steering wheel controls working great with RR.
Now question #2, how do I control Fusion Brain from AutoIt using COM?
I'm guessing something like this:
Code:
$FB = ObjGet("","FusionCOM.FusionServer") $FB.usboff
And in the Fusion Config
Code:
<com status="enabled"> <commands> <command id="usboff" minimum_delta_vote_time="100"> <do function="trigger output" functionTargetID="Digital Output 0" vote_opinion="off" vote_priority="medium"></do> </command> </commands> ...etc
But of course it's not that simple. Anyone have any ideas?
JiC is offline   Reply With Quote
Old 12-18-2008, 11:42 AM   #2
stealinfool's Avatar
stealinfool is on a distinguished road
You shouldn't have logic (do_function) in the commands section.
Whatever your AutoIt COM name is:
Code:
<com status="enabled"> <executable_commands> <external_COM_id id="INSERT YOUR COME HERE">
Then your command and parameter (what AutoIt is being told by MDX)
Code:
<command internal_id="command_xx" external_command="xx"> <parameter order="0" external_command_parameter="xx" /> </command>
You're have to find those values out an insert accordingly.
Then for the logic
Code:
<do function="external command" functionTargetID="command_xx" vote_opinion="xx" vote_priority="Medium"></do>
DON'T PANIC.
Previous install pics in 2k3 S10
Project CarPc V2
stealinfool is offline   Reply With Quote
Old 12-21-2008, 10:03 PM   #3
JiC
stealin what you are describing is how you'd send commands to AutoIt FROM MDX. I'm talking about doing the reverse.
In that case you CAN have logic like do function in the commands section.
This whole thread is moot now. I was trying to do this as a workaround since I couldn't find a way to get RR to send commands successfully, but that has been resolved (See this thread)
