Ok so found a way to do it. Hopefully this will help some other people. This same idea can be used with steering wheel controls to create different actions if you hold down the buttons. Also it seems to me like since the COM update the MDX is much more accurate with the timer and delta_vote times. Before they seemed random, now they work as they should.
Now I have it set up so if you hold 'next track' for longer then one second it starts to send fast forwards every half second after that. If you hold next track for less then a second and let go it advances to the next track.
This timer in my code below allows me to use the fusion brain to trigger a relay for about a second then turn it back off. RR calls a function that turns on a digital output and sets usbstatus to 10 (high) and usbcount to 0. The relay is used to interrupt the +5V wire on the USB cable leading to my hub up front. This solves all pesky problems with my hub and touchscreen on resuming from hibernate (which the fusion brain always comes out of perfectly
Code:
<if fire_on="logic" minimum_delta_vote_time="150" id="CountUSB">
<boolean_operation type="and">
<parameter1>
<boolean_operation type="greater than">
<parameter1>
<variable do="get" name="usbstatus"></variable>
</parameter1>
<parameter2>
<number>5</number>
</parameter2>
</boolean_operation>
</parameter1>
<parameter2>
<boolean_operation type="less than or equal to">
<parameter1>
<variable do="set" name="usbtime">
<operation type="add">
<parameter1>
<variable do="get" name="usbtime"></variable>
</parameter1>
<parameter2>
<number>1</number>
</parameter2>
</operation>
</variable>
</parameter1>
<parameter2>
<number>10</number>
</parameter2>
</parameter2>
</if>
<if fire_on="logic" minimum_delta_vote_time="100" id="ResetUSB">
<parameter1>
<parameter1>
</parameter1>
<parameter2>
<number>5</number>
</parameter2>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
<number>10</number>
</parameter2>
</parameter2>
<then>
<do function="Change Variable" functionTargetID="usbstatus" vote_opinion="0" vote_priority="Low"></do>
<do function="Change Variable" functionTargetID="usbtime" vote_opinion="0" vote_priority="Low"></do>
<do function="Trigger Output" functionTargetID="Digital Output 0" vote_opinion="Off" vote_priority="Low"></do>
</then>
</if>
