Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 01-08-2009, 10:18 PM   #1
GadgetBandit's Avatar
GadgetBandit is an unknown quantity at this point
Graph question?
How would I slow a graph down? I would like to see a point added only every 6 minutes, giving me a 24 hr history.
Thanks,
GadgetBandit
<!-- Begin Graph Instances -->
<graph id="My Test Graph">
<line line_colour="255,70,210,70" line_width="3"></line>
<display size="240,99" location="38,365" page="0" z_order="0"></display>
<options value_minimum="0" value_maximum="120" time_maximum="300" axis="horizontal"></options>
<monitor timer="GUI Timer" target_type="variable" target_ID="temp 1"></monitor>
</graph>
GadgetBandit is offline   Reply With Quote
Old 01-09-2009, 01:24 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
change the max time setting
Old 01-09-2009, 02:04 AM   #3
Cool. Thanks. I was way too timid in changing the value to notice any change.
GadgetBandit
Old 01-21-2009, 02:56 PM   #4
There are 4 lines in the graph. Setting the max_time at 5000 does slow it, some. I'd like more, but where does the amount of data become a problem?. Since time is still relative, could a counter be used to sample the variable only after a certain number of cycles, then set max_time could be set back to a low number? I love to have a 24 hr curve.
Thanks,
GadgetBandit
Old 01-21-2009, 03:08 PM   #5
2k1Toaster's Avatar
Thanks,
GadgetBandit
It is pretty small memory footprint for each data point but I have never tried anything that big, you can always just try and see what happens
Old 02-26-2009, 01:33 AM   #6
I set max time at 6000 and MDX dies with the error "Index out side bounds of array". Is there any way you can made graphing a function, so we can trigger adding a point, say using a counter?
GadgetBandit
Old 07-20-2009, 12:55 AM   #7
Could a graph instance monitor something other than a timer? A variable set by "when", maybe? I could add a point an hour! Anything close?
Thanks,
GadgetBandit
heavy-duty OBD standards support question Michael2006 Engine Management, OBD-II, Engine Diagnostics, etc. 0 01-07-2007 05:13 AM
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 06:15 PM
Forum Etiquette Enforcer Newbie 5 01-09-2006 06:58 PM
Paint And Polish Question gboy Fabrication 8 08-13-2005 08:22 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 10:03 AM
