Need Help!
Hi. I have a version 3 brain and really need some help.
I have a Dell laptop running XP.
I downloaded and installed .NET 3.5 and DirectX 9.0C
I removed the drivers per your instructions. I did this twice. Prior to installling the new drivers I tried to get the configuator to find a brain and it could not. This I took as good.
I then installed the new drivers and the configuator found the brain, and I ensured it was labeled as version 3.
I used the Kitty wizzard to make a quick skin to see the voltage inputs.
So far so good. I started the Fusion Control Center and installed a jumper from the +5 VDC pin to the input pin on each analog inputs, one at a time. I got no response.
How can I troubleshoot?
Thanks,
Fred
