Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 03-27-2009, 08:40 AM   #1
boy36 is an unknown quantity at this point
Control OEM radio from my head unit
Hi
I have same questions about Fusion brain.
I want to control my oem radio with carpc.(ON,OFF,CD,......)
This is oem radio plate.
I want to control this push buttons with fusion brain.
I m solder wire for each button.
For do that if i must buy fusion brain and relay for each button?
Sorry for my english.
boy36 is offline   Reply With Quote
Old 03-27-2009, 10:41 PM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
To do that, you need 1 fusion brain (can handle 16 relays) and then 1 relay for each button
greenman100 is offline   Reply With Quote
Old 04-06-2009, 01:50 PM   #3
Iamthehor is on a distinguished road
May not need relays - they're probably all 12V low current. Hard to determine that for sure though.
Iamthehor is offline   Reply With Quote
Old 04-25-2009, 04:17 PM   #4
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
I'm using optoisolators for controlling the push buttons for my HVAC unit. This is essentially the same problem as you're having. I just hooked up a 1kOhm resistor to pin 1 of my optoisolator (LAA110 - http://www.clare.com/home/pdfs.nsf/www/LAA110_R09.pdf/$file/LAA110_R09.pdf). It seems to work really well, when the digital output on the fusion brain goes high, the optoisolator (or a solid state relay) connects the terminals, emulating a push button
0l33l is offline   Reply With Quote
head unit or no head unit... that is the question FusionFanatic General Hardware Discussion 49 08-27-2007 12:21 AM
Can You play radio from a spdif out on your head unit Celica25th Car Audio 1 06-04-2007 09:47 PM
Radio with no head unit? spoonraker General MP3Car Discussion 2 11-07-2006 03:12 PM
choosing a head unit demonr Car Audio 3 09-17-2006 01:56 AM
New Sony head unit - botched wiring... SamDude Car Audio 4 09-09-2004 05:21 PM
