Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 04-07-2009, 08:59 AM   #1
olds69 is an unknown quantity at this point
Configurator and invisible instances
Hi
I have a small problem when using the configurator.
I am developing a skin but suddenly all my instances becomes invisible when I open a page to edit the graphics properties.
When I open the page for edit everything is white, the background, and all the instances are gone, I can edit the instances by left clicking on them but no matter what I do I can not get them visible. (also played around with the z-order to no avail.)
Running the MDX everything seems normal, when looking at the page in the overview window without opening them they look ok…
Does anyone have a god idea on how to fix this?
TIA
Olds69
olds69 is offline   Reply With Quote
Old 04-08-2009, 12:09 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
When you move your mouse it should redraw. If it is not, then there is a GDI+ problem somewhere. Do you have any sort of weird hardware setup?
Old 04-10-2009, 11:31 AM   #3
No strange hardware as far as i know :-)
2 months old Dell laptop, also tried it with my old laptop and the same happens there.
(both run XP)
I should mention that the skin is quite large, with 4 pages and 5-8 multi images on each, 270 images in each multi image...
The old laptop spin up the CPU fan and load the CPU heavily when I move the mouse cursor (in edit mode) so it is obviously trying to do something...
When I start from scratch everything works as it should, have not gotten to the point where the old skin malfunctioned though…
Olds69
REQUEST: Run Multiple RR instances Jarrod Road Runner 33 12-21-2008 08:54 AM
prob running multiple instances of RR carlos067 Road Runner 3 12-08-2008 10:13 AM
Ok. dual screens 1 controls the other w/ multiple instances. Custommx3 Road Runner 13 09-04-2008 08:36 AM
controling two instances of RR tundra2000 RR Skins 11 09-07-2007 03:47 PM
Two Instances of FP and two sound cards djXternal FrodoPlayer 7 04-13-2005 12:58 PM
