Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 04-26-2009, 06:43 AM   #1
QuickSSilver is an unknown quantity at this point
Hiding Mouse Cursor in MDX
Just wondering if it is possible (via an option / command line switch) to hide the mouse cursor when running MDX? I have a touchscreen so can control all my buttons with it; the mouse cursor is actually redundant.
QuickSSilver is offline   Reply With Quote
Old 04-27-2009, 01:53 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
No there isnt a way to hide the cursor. Are you using it in a frontend, or by itself?
I can add it as an option pretty quickly. I'll try to incorporate it into the next release.
Old 04-27-2009, 08:03 PM   #3
That would be awesome
Using it in a frontend, hence would like to disable the mouse cursor. Perhaps a setting in the xml file or a command line switch? I'm not sure how my frontend (Centrafuse) handles passing on parameters to an embedded app though.
Old 04-27-2009, 08:57 PM   #4
bratnetwork's Avatar
bratnetwork is an unknown quantity at this point
Ride Runner hides it still when you embed MDX into a skin
bratnetwork is offline   Reply With Quote
Old 04-27-2009, 09:57 PM   #5
2k1Toaster's Avatar
That's what I thought...
I would have figured CF did the same.
Old 05-22-2009, 03:59 PM   #6
2k1Toaster's Avatar
Ok, it is done.
In the main graphics part of the configuration file add: HideCursor="True" (or "False" which is the default so it isn't needed).
So my main graphics section starts like this:
Code:
... <graphics> <!-- Begin Global Graphic Settings --> <main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="False" MinimizeToSystemTray="True" HideCursor="True"></main_display> <!-- End Global Graphic Settings --> ...
This has not been released yet but next release should include it. Any exe with a version number of 5.0.0.130 or higher will include this feature.
Real solution to G4 GPS being detected by Windows as crazy serial mouse? johnk Mp3Car Infill G4 - Double Din Car Computer 17 03-22-2009 11:00 AM
How to use a configuration file created by the Configurator with MDX 2k1Toaster FB Documentation and Tutorials 15 09-08-2008 05:36 PM
Hiding the mouse Speg Media Engine 1 06-22-2005 02:58 AM
PS2 3 Button(Rotary Wheel) Mouse Properties? nFiniteTuning Input Devices 4 03-12-2005 10:43 PM
hiding the mouse when its not needed Alives General MP3Car Discussion 8 07-07-2002 12:42 PM
