Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 05-31-2009, 04:52 PM   #1
menthos is an unknown quantity at this point
help with fusion brain
i have just recieved my fusion brain v4 +2temp sensors and accelerometer yesterday, and tried to use the configurator to make a simple test program to test my sensors...
but it turned out to be not so easy as i thought...
i have been trying to use the Ninja tool to create a config file for MDX, but when i run it, i get some really strange values:
as you see i get some strange values both for temp sensors and accelerometer..
so i tried to use a virtual brain instead, but then i got this fail:
when i click continue, it reads the sensors value fine and i can see the value om the accelerometer changing when i move it...
what am i doing wrong?
menthos is offline   Reply With Quote
Old 06-03-2009, 02:42 PM   #2
bump?
anyone can tell me why i get theese values??
Old 06-03-2009, 05:27 PM   #3
after studying the temp function i found 2 mistakes....
my temp function goes like this:
input_temp
subtract 4
multiply by 1000
divide by 1953
but after i changed the two values in bold to 0,4 and 19,53 the temperature started to make a bit more sense...
now i actually can read the temperature, but there is still something wrong cause i get some like 15 digits:
i tried to divide the final value by 1000000 in the temp function, but without luck...
Old 06-03-2009, 06:44 PM   #4
Fusion Brain Creator
greenman100 is on a distinguished road
Is your computer set up in the US or international?
greenman100 is offline   Reply With Quote
Old 06-04-2009, 01:41 AM   #5
it's a US install but all settings (keyboard and regional) are set to danish..
Old 06-04-2009, 01:42 AM   #6
That's why. PM 2k1Toaster for more info.
Old 06-04-2009, 01:43 AM   #7
ok, will try that.... thanks for help
Old 06-09-2009, 09:10 AM   #8
still no answer from 2k1Toaster
Old 06-09-2009, 02:53 PM   #9
He's in the hospital. He'll reply as soon as he can.
Old 06-09-2009, 02:54 PM   #10
also, i found this:
http://www.mp3car.com/vbulletin/fusi...og-inputs.html
Old 06-09-2009, 03:03 PM   #11
ohh well then i got my answer... ^^
hope bug will be fixed soon
Old 06-09-2009, 04:13 PM   #12
Dan2008 is an unknown quantity at this point
Nothing serious I hope...send him a Get Well from everyone on the forums.
Thanks,
Dan
Dan2008 is offline   Reply With Quote
Old 06-09-2009, 05:05 PM   #13
it's not life-threatening at all from what I understand. he should be back soon.
Old 06-12-2009, 10:30 PM   #14
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Its because the decimal point vs. comma for separating a number is different. I will have to fix it but easiest is to change regional settings to US/Canada or something.
Old 06-13-2009, 11:06 AM   #15
well i can live with it for now. but i really hope there will be an update to fix the problem sometime...
*NEW* USB Input/Output Board -- Fusion Brain 2k1Toaster Fusion Brain 1122 11-07-2009 12:21 AM
eyeR MOD for the Fusion Brain, add PWM, Servo and remote control. (eyeR Interceptor) Civic Modz Fusion Brain Innovations 17 01-16-2009 10:48 AM
September 9, 2008 - The Fusion Brain – How do you use it in your car? Heather Mp3Car Blog Talk 3 09-23-2008 10:00 PM
How to add a Fusion Brain instance to your configuration file 2k1Toaster FB Documentation and Tutorials 0 06-07-2008 09:42 AM
Noob has some biginner questions about the Fusion Brain phreaknes Fusion Brain 14 04-29-2008 03:57 AM
