Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 06-05-2009, 07:11 AM   #1
QuickSSilver is an unknown quantity at this point
100% CPU usage running MDX
Somewhere along the line something has happened on my computer that is causing issues with Fusion Control Centre. Basically, whenever MDX is in the foreground, the CPU usage sits at 100%. This happens no matter which skin I use - even the default one and if no brain is attached. If the program is minimised, it drops down to the (expected) single figures.
I have tried
  • reinstalling the latest MDX software and updates and rebooting;
  • installing the latest directx redistributable (from March 2009);
  • running in "basicgui" mode;
  • playing around with the "gui" timer to make it refresh much slower
and still have this CPU usage problem. Any suggestions as to what might be causing this issue?
P.S. This may be unrelated but watching the memory usage it appears to be going in a pattern repeating every few seconds - e.g. 39,000 kB, 56,000kB, 70,000kB and then returning to 39,000kB, etc. (these numbers are not exact but merely representative).
QuickSSilver is offline   Reply With Quote
Old 06-06-2009, 11:46 AM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
What CPU are you running?
greenman100 is offline   Reply With Quote
Old 06-06-2009, 09:32 PM   #3
I am running a VIA C7 2.0 GHz with 1Gb RAM under Windows XP. Never had a problem running FCC MDX until recently. No other applications are running while FCC is maxing out my CPU. No other process is using more than the occasional 1 or 2% CPU.
I have just tried removing FCC MDX and all of the .NET frameworks installed on my computer then reinstalling FCC MDX and it still has the CPU usage issue. I'm puzzled as what to do next....
Old 06-07-2009, 06:34 PM   #4
Wait for Nick (2k1toaster) to get out of the hospital.
Old 06-08-2009, 06:17 PM   #5
GadgetBandit's Avatar
GadgetBandit is an unknown quantity at this point
What are the timers set to?
GadgetBandit?
GadgetBandit is offline   Reply With Quote
Old 06-09-2009, 12:41 AM   #6
Ok... I think I found the problem. Somewhere along the line (probably due to a Windows update) the Direct3D Acceleration option under the Display tab of the dxdiag.exe utility had been disabled. I simply enabled it again and the CPU usage has now dropped dramatically when the MDX window has focus
This testing is just with the default skin; I have yet to try it with my custom skin, but don't see why it wouldn't work now.
Old 06-27-2009, 06:25 PM   #7
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Good to know it is working. Also just FYI the Virtual Brain is pretty cpu intensive as well so I dont know if that would work on a Via chipset.
RR with Jetway J7F5 CPU usage overlander Road Runner 6 09-19-2008 03:24 AM
Strange CPU usage BikeBoy24 Road Runner 3 10-04-2005 03:20 AM
EPIA M10000 CPU usage by SVCHOST.EXE Bugbyte General MP3Car Discussion 6 05-15-2005 09:49 PM
cpu usage using 100% michaelrj9 Road Runner 4 05-08-2005 08:11 PM
winamp cpu usage awh4992 Software & Software Development 8 01-07-2004 11:13 AM
