Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > FB Software
Old 07-20-2009, 10:49 PM   #1
GadgetBandit's Avatar
GadgetBandit is an unknown quantity at this point
when statements
<when year="XXXX" month="XX" day="XX" hour="XX" minute="30" second="XX">
any way to substitute a variable?
<when year="XXXX" month="XX" day="XX" hour="XX" minute="var" second="XX">
or
<when "var">
and if that's possible, how do you concatenate strings?
Thanks,
GadgetBandit
GadgetBandit is offline   Reply With Quote
Old 11-04-2009, 11:59 PM   #2
JiC
JiC is an unknown quantity at this point
<whens> look like this:
Code:
<boolean_operation type="and"> <parameter1> <boolean_operation type="equal to"> <parameter1> <variable do="get" name="mpp"></variable> </parameter1> <parameter2> <number>1</number> </parameter2> </boolean_operation> </parameter1> <parameter2> <boolean_operation type="less than"> <parameter1> <analogue id="SWC" time="0"></analogue> </parameter1> <parameter2> <number>0.2</number> </parameter2> </boolean_operation> </parameter2> </boolean_operation>
if mpp==1 && SWC < 0.2 then ...
I'm definitely not the expert, but I don't think you'll be able to find things like date and string manipulation in the Fusion environment.
I think a better way would be to do your logic in another program, then have it use the COM interface to trigger digital outputs or whatever it is you're after.
JiC is offline   Reply With Quote
Variable syntax questions Iamthehor FB Software 14 02-25-2009 10:58 PM
Suggested reading to better understand graphical interface Dagwood FB Documentation and Tutorials 6 09-24-2008 10:12 AM
police laptop\radio frequency jdogg1583 Hardware Development 63 03-31-2008 05:32 PM
So...America IS hated? sdashiki Off Topic 48 09-09-2005 11:21 AM
