Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > FreeDrive > FD FAQs
Old 02-20-2005, 12:05 PM   #1
FreeDrive Creator
CdRsKuLL's Avatar
Can FreeDrive be embedded into Frodoplayer ?
To get Freedrive to work with Frodoplayer you need to use a wrapper which Frodo made. Here are his instructions
This is how it works.
Take these files, put them in your freedrive directory.
Verify in FDWrapper.ini that the path to FreeDrive.exe is correct.
In the FrodoPlayer directory, open FrodoPlayer.ini.
At the bottom under [GPSDEFAULTPATHS],
change the DEST3 line to equal:
DEST3=C:\Program Files\FreeDrive\FDWrapper.exe
(or wherever it is)
Then in FrodoPlayer settings 2, choose the Ninja Monkey option.
Make sure "Use External GPS Application" is NOT checked.
You're good to go.
Frodo
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 02-20-2005, 05:57 PM   #2
I'm sorry, and you are....?
frodobaggins's Avatar
Note: The next FP version will have native support.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 01-18-2006, 11:40 AM   #3
SimonTALM's Avatar
I use this wrapper and it works very well, I have only one comment against it - to move forward a track I have to hide FreeDrive and go back in to Frodo tap next track and return to FreeDrive through the menu and GPS button - I can't seem to find a way to get a next track button on the the top bar.
Am I missing something or do I have to wait until the next version of Frodo?
Status: [000000----] 60% - Basic installed and working - Phase 1 nearly there!
Spec: Epia MII 12000, K301 7" InDash VGA, Jabors VW Interface, Slim Slotload CDRW/DVD, 512MB RAM, 2x40GB 2.5" HDD, 512MB CF Card.
Planed: WiFi, USB GPS, BlackBox Video
SimonTALM is offline   Reply With Quote
Old 02-15-2006, 04:31 AM   #4
feral's Avatar
Trying to use it in mediacruiser.. Not yet successful, working on it. Needs a window name to maximise and minimise, tried FDWrapper + Freedrive.. no workee.. Still investigating
May yet switch to FP Just need to use the thinnest possible front end.. as PC is low powered..
feral is offline   Reply With Quote
Old 02-17-2006, 05:32 PM   #5
FreeDrive Creator
CdRsKuLL's Avatar
Try the new FD1.0, things have changed slightly.. use name FreeDrive and see how you go
Old 04-08-2006, 03:43 PM   #6
can i get FD to work with microsoft S&T 2006??/
nyctitan is offline   Reply With Quote
Old 04-08-2006, 03:50 PM   #7
Neither darque nor pervert
DarquePervert's Avatar
You need to read the manual and/or the FAQs before asking stupid questions.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 07-25-2006, 03:57 PM   #8
Maņana's Avatar
I can't get this to work properly with FD1.0
Frodo launches the wrapper, and the wrapper launches FD, but it doesnt embedd properly. The wrapper gets black, and shows nothing.
FD works good when used alone...
My carputer
Old one
Maņana is offline   Reply With Quote
Frodoplayer 1.09 Take 3 with Map Monkey 1.1.3 Embedded (Title Bar) Chita79 FrodoPlayer 37 03-06-2005 10:17 PM
Destinator is embedded in FrodoPlayer weekendowel GPS 0 10-24-2004 12:56 PM
Bug Reports 1.09 frodobaggins FrodoPlayer 279 10-22-2004 10:24 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 12:25 AM
Running FrodoPlayer on Windows XP Embedded? Lupo FrodoPlayer 11 07-23-2004 07:50 AM
