Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > FrodoPlayer > FP Bug Reports
Old 02-21-2005, 07:11 PM   #16
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
just wanted to give you guys a status update, I just got done installing my new shuttle PC to replace my old carputer, it resumes from hibernation normally, it picks right back up where it left off. without having to touch the screen.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 02-22-2005, 10:31 AM   #17
kuo
kuo's Avatar
kuo
Angry
i never got anywhere on this either. i just gave up and started running roadrunner on the laptop that was giving me trouble. i guess there are just some motherboards out there that just don't like to play nice with hibernate.
kuo is offline   Reply With Quote
Old 02-27-2005, 07:27 PM   #18
jasonjsimon is on a distinguished road
Cause of rehibernation found!
I've had this problem for a long long time. Nice to see that I'm not the only one (sorry). I have found the the 5 minute hibernate problem is OS related. Check this out.
I think the requirement for a mouse movement or keystroke before resuming playback may be a different problem (that I have too).
Maybe someone can figure out how to adjust the inactivity timer in XP....
jasonjsimon is offline   Reply With Quote
Old 05-08-2005, 08:10 PM   #19
Dr Watson is on a distinguished road
Has a solution been found to the problem of frodoplayer not playing without a mouseclick after a resume from hibernation? That link to the Microsoft KB article was great, how they offered no solution or workaround.
Dr Watson is offline   Reply With Quote
Old 05-08-2005, 08:19 PM   #20
MySQL Error
jcdillin's Avatar
I fixed it by going with a diffrent motherboard, but I havent found any other way yet for my previous motherboard
肚子笑痛了
S60 Install
Old 06-24-2005, 08:16 PM   #21
DJKhan85's Avatar
DJKhan85 is on a distinguished road
I have a similar situation to you guys. After coming out of hibernation, frodplayer loses the sound card aparently. Also if I leave frodoplayer open and then go to hibernation it takes twice as long to resume than if I just closed frodo and hibernated. I can't figure this thing out. The funny thing is that frodo will register the click sounds when pressing buttons. I believe the problem lies with my sound card. I jsut redid my setup and the only differences are that now I have SP2 and am using FDDshow or whatever it is called. Other than that everything is the same.
Computer:
COMPLETE SYSTEM OVERHAUL!!!!!!
STAY TUNED IN THE UPCOMING WEEKS!
DJKhan85 is offline   Reply With Quote
Old 02-20-2006, 11:05 AM   #22
kuo
kuo's Avatar
kuo
just a quick update with my solution to the "resume from hibernate needing user input before the computer will do anything problem".
parts: usb optical mouse, cpu fan, tape
so i taped the optical mouse to the fan and hooked up to my cnx p1900. whenever the laptop turns on, the fan turns on. because the optical mouse sits directly on top of the fan, the mouse starts moving. that solves the input problem.
the next issue was how to get the mouse to stop moving. having the mouse constantly would screw up a lot of functions in most frontends. to correct this i used girder, autoit, and devcon. onresume, girder executes an autoit script that uses devcon to disable the usb optical mouse. onsuspend, the opposite happens and the mouse is enabled. i've tested it and it does work.
my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
Old 08-06-2006, 04:57 PM   #23
MobiTekLink's Avatar
MobiTekLink is on a distinguished road
My issues are that I go into hibernate and coming back the touch screen doesnt work correctly until I use a mouse. It's almost like the touch screen is "right clicking' and it gets resetted after using the mouse. Also the touch screen is only highlighting the last operation used before hibernating. :?? Im baffled, I've used all the drivers and disabled "auto right click" on the touchkit utility.
08 Lincoln Navigator www.mobiteklink.com
MobiTekLink is offline   Reply With Quote
m10000 doesnt always resume from hibernate fasternfaster General Hardware Discussion 0 11-29-2004 04:21 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 01:25 AM
resume from hibernate turbochris General Hardware Discussion 3 05-28-2004 02:11 PM
Trigger script/command on resume from hibernate? tejesh83 Software & Software Development 9 10-24-2003 08:05 PM
M9000 display size on resume from hibernate GingerPrince Software & Software Development 2 05-03-2003 10:30 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
