Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > FrodoPlayer > FP FrodoComm > FP FCSH Services
Old 05-14-2005, 08:33 PM   #1
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
Frodo Authored Services[Discussion Thread]
You can discuss the services that I authored here.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 05-15-2005, 03:36 AM   #2
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
How about adding a function to detect shutdown/restart/hibernate and resume from hibernation to PowerFunctions?
0l33l is offline   Reply With Quote
Old 05-15-2005, 03:45 AM   #3
I could do it, but you likely wouldn't get the message until after hibernate occured.
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-15-2005, 03:54 AM   #4
My Village Called
0l33l's Avatar
Well, in NaviVoice, I get the message and I have time to pause recognition. How do you think I got SAPI to resume after hibernation
So, is FC that much slower
Old 05-15-2005, 04:24 AM   #5
Super Moderator
xBrady's Avatar
xBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to behold
It depends on how you implement it. You can pause hibernation until you are done doing whatever you need to do.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 05-15-2005, 04:33 AM   #6
My Village Called
0l33l's Avatar
I didn't even needed to do that. I guess my events were executed faster than the hibernation.
Old 05-15-2005, 03:41 PM   #7
That's not the problem. It's just the way Windows works, unless you do some special handling of hibernation yourself, sending messages will likely not reach the other apps until they come back, as they have prepared for hibernate. The reason you can pause Sapi is because it is running in your own app.
We can try it out and see if it works though
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-15-2005, 03:45 PM   #8
My Village Called
0l33l's Avatar
True, or send that app a command after your app has finished executing its instructions
Old 05-18-2005, 08:45 PM   #9
Chairboy's Avatar
Chairboy is on a distinguished road
Sweet, people with USB devices that are recalcitrant when it comes to waking up from sleep/hibernation will be able to use this to launch a mechanism to re-initialize the offending hardware.
Chrysler 300 - Fabricating
http://hallert.net/
Chairboy is offline   Reply With Quote
Old 05-22-2005, 11:58 PM   #10
Ok. I have found several bugs in my joystick service, however they are easy to fix.
But now I have another problem, and I need input on how to solve it.
Ok, the service enumerates and post events for 4 joysticks.
What do I do if the user decides to start a game or some other app that needs
the joysticks ? How should I proceed there ?
Help guys.
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-23-2005, 12:01 AM   #11
My Village Called
0l33l's Avatar
Help guys.
Check for directx or opengl.
Old 05-23-2005, 12:06 AM   #12
explain
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-23-2005, 12:09 AM   #13
My Village Called
0l33l's Avatar
explain
Well, if someone launches a game, then they are probably going to be using either directx or opengl. If you check if those are running, then you can disable the service for a while.
Old 05-23-2005, 12:16 AM   #14
Super Moderator
xBrady's Avatar
But what if the user launches an app that uses opengl/directx but doesn't use the joystick?
Installed.
Old 05-23-2005, 12:19 AM   #15
My Village Called
0l33l's Avatar
Ummm... I dunno.
My idea is to have the service spy on what apps are open, and if an app matches one of the list then then joysticks won't be intercepted.
Frodo Authored Services frodobaggins FP FCSH Services 5 05-18-2005 06:45 PM
reinstall frodo after using FM radio Erwin FrodoPlayer 12 04-06-2005 10:28 AM
Frodo Album Art? Hopperhawk FrodoPlayer 2 02-07-2005 12:40 AM
What else is up your bag of tricks frodo? nappyjim FrodoPlayer 0 10-26-2004 01:57 PM
Switch between Frodo player and GPS (IGuidance)? Nanozic FrodoPlayer 2 07-12-2004 02:58 AM
