The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > FrodoPlayer > FP FrodoComm
Thread Tools Display Modes
Old 05-22-2005, 05:16 PM   #61
9 Fingered Administrator
Lesbian
frodobaggins's Avatar
Vehicle: 1998 Ranger/1991 Sunbird
My Photos: (0)
Quote: Originally Posted by beernutz
Hi, first off, i want to thank you (Frodo and the community) for frodoPlayer! I am quite impressed with the stability, and feature set!
Second, i am a programmer by profession. Not that i am all-knowing, but i do have some skill in this area.
Finally, i am looking for some information on getting the comServicesHost and the modules that come with it installed properly. For some reason i am unable to get any of the services to show (register?) in the servicesHost application.
I have some programming i would like to experiment with. Things like a thumbs up and thumbs down to rank songs while they are playing. Once your library gets so large, it can become a problem keeping it all organized and cleaning out the bad songs. With a tivo like Thumbs scheme, it would be a LOT easier to manage this. I am thinking of a button to basically remove a song from active rotation as well. Something you may have collected, but not really had time to listen to. This way if you hear a song that you hate, you can just mash the "NUKEIT" button and review the bad ones later.
I promise i will not be obtuse and will give back as much as i can. Please help me with this if you have the time.
Anyway, there are lots of other ideas i have, but this is where i would like to start.
Thanks again for a great platform and any help!
I don't think my installer is registering FrodoComm itself correctly.
Shut it all down and follow the directions in post 31:
http://www.mp3car.com/vbulletin/show...0&postcount=31
See if that helps.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Sponsored Links
Old 05-22-2005, 06:03 PM   #62
My Photos: (0)
hmmmmm.
I had already read post #31 and tried it as soon as i saw it. I should have mentioned that in the previous post. I also tried manually registering some of the services, but that did not work either.
Your services host application shows running, disabled, and debug windows all blank.
Color me
beernutz is offline   Reply With Quote
Old 05-22-2005, 06:06 PM   #63
Lesbian
My Photos: (0)
Did you install MS XML 4 SP2 ?
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-22-2005, 06:12 PM   #64
My Photos: (0)
doh!
<sheepishly>
no.
Now going to recheck ALL the pre-Reqs again.
</sheepishly>
i cant even
(can you tell i like the stupid little emote animated gifs?)
Old 05-22-2005, 08:31 PM   #65
My Photos: (0)
My problem is now corrected
The updated XML control appears to have corrected the issue.
In summary:
be more thorough than i was and CHECK ALL PRE-REQUISITES!
I THOUGHT i has the right version of the XML parser, but i did not.
Once i updated, all was fine.
Maybe i could code a preinstall check for you Frodo?
would save further issues of this type.
Old 05-23-2005, 05:06 AM   #66
My Photos: (0)
Question: How to find currently playing song
I have a VB.net app set up now receiving and broadcasting events and this seems to be working nicely.
I adapted your windows message code to post the <skip to next song> message, and this seems to be working well too.
How would i then ask the player for the name of the currently playing song?
Side question: Is there a list of messages that the FPPLUG-REMOTE window responds to?
Final question (for this post at least): I notice that the CommID is not unique? my app is assigned number 34 for instance, but there is a service with the same ID at the same time. Is this intentional?
Getting close and am excited about the possibilities!
Thanks again!
Old 05-23-2005, 10:00 AM   #67
ImInSanDiego's Avatar
Vehicle: '05 Mercedes C230K
My Photos: (0)
Thanks again!
The CommID should be a new number every time you start your app. Are you saying that there is another FrodoComm service with the same CommID?
ImInSanDiego is offline   Reply With Quote
Old 05-23-2005, 12:21 PM   #68
Lesbian
My Photos: (0)
That's not possible. It changed, and he didn't query it right or update with member status.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-23-2005, 06:10 PM   #69
My Photos: (0)
Has anyone had any problems in their app when using FrodoComm? Sometimes my app will hang upon execution and then I might receive a message "problem sending message to service" when I terminate it. At other times the app will come up fine, but after about 4 executions, it will hang. I have to terminate it. This is a very simple app that just sends a volume change message to the network and then terminates. I'm just curious if anyone has seen weird behavior like this?
Old 05-23-2005, 07:54 PM   #70
My Photos: (0)
CommID
I am not seeing duplicated CommID's any more. Not sure what i was doing wrong to see them before.
I do however have a few ghost entries in the registered services list. I assume i got these by failing to call FC.EndProcessing() before my app terminates. Where are these entries stored? I would like to clean the errant ones.
And I would really like to know how to query the name of the currently playing song.
Thank you.
Sponsored Links
Old 05-23-2005, 07:57 PM   #71
My Photos: (0)
reply to ImInSanDiego
So far i have not seen the problem you describe. I wonder if the service host is dying for some reason?
Old 05-23-2005, 08:22 PM   #72
My Photos: (0)
Thank you.
The ghost entries are caused by not calling endprocessing. I have asked about cleaning them up before, but I don't think I got an answer. They just stick around until you reboot I believe.
I don't believe that Kevin has published the messages that can be sent to the new FP yet, so you wouldn't have much luck with querying the current song.
Old 05-23-2005, 08:25 PM   #73
My Photos: (0)
k, thanks for the reply. As long as they clear up on reboot that is fine.
Frodo, is there any chance of getting some kind of list? or a little more info on how to proceed?
Thanks much for all the help guys!
Old 05-23-2005, 09:41 PM   #74
Lesbian
My Photos: (0)
Is the app compiled and not in debug mode when this happens ?
And could you post any and all exact error messages ?
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-23-2005, 09:42 PM   #75
Lesbian
My Photos: (0)
There is a sendmessage list published for the current version.
The new version won't use it. And the frodocomm messages
for it aren't standardized yet.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
