Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > FrodoPlayer > FP FrodoComm
Old 05-01-2005, 11:34 PM   #1
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
[Release] FrodoComm, and FrodoComm Services Host
Here are the links, explanation below.
FrodoComm
What is FrodoComm ?
It's an "Asynchronous Extensible Inter-Process Communication Server"
It's purpose is to allow interprocess communication for apps and services
via a common interface. The docs still need to be written, but some uses
are released as source with the app and the services launcher.
What is FrodoComm Services Launcher ?
It is a small inteface that supports "COM" plugins or services, as well
as plugins written in VBScript or Javascript.
It's primary purpose is to provide a place for hosting services that don't
require an interface, but provide useful things. The services however
do not have to use FrodoComm, so the launcher can be used for other
purposes.
Who would use either of these ?
Well right now, since there is no developer support, no one
But as more developers add support to their apps, the uses
will become obvious. (4 developers commited now, including me)
Any app can join the FrodoComm network, it is not limited to just these
services.
For developers, two interfaces are provided, a user control, and a class
module. FrodoComm.exe itself should not be used directly, the control
or class only should be used, as they are threaded when not run in debug
mode. This prevents blocking.
6 demo plugins with source code are provided for developers to get
their feet wet.
4 in VB6
1 in VB Script
1 in Javascript
More language examples will follow, including C#, VB.NET, C++, and Delphi.
I hope to be on hand to give out advice and more documentation
as necessary for use.
A list of dependencies for the apps is as follows:
(Links to come, most developers will know how to get these)
--MS XML 4 SP2 or higher
--MS Winsock Control
--SAPI 5.1
--IE 6
--MS Script Control
--MS Scripting Runtime
For devs wanting to check it out and start working now, check the app
folders for some instructions and source code. Also a demo app is provided.
Note: To bring ServicesHost visible after launching, either relaunch, or
press CTRL + SHIFT + ENTER.
I know I haven't explained enough, but maybe you devs can ask the right
questions so I can rectify this.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 05-01-2005, 11:40 PM   #2
Super Moderator
xBrady's Avatar
xBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to behold
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 05-02-2005, 12:02 AM   #3
There are also things such as:
1. pre-defined "canned" messages
2. language extenders for the scripting engines
I will explain these soon as well.
It was a lot to package up !!
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-02-2005, 12:51 AM   #4
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
Yem, I'm one of the developers. Delphi code needed
Things that will be on the network:
iGuidance skin I'm working on
NaviVoice
GammaControl
0l33l is offline   Reply With Quote
Old 05-02-2005, 12:57 AM   #5
I will try to answer any questions tomorrow. I must rest now.
I'll be off work tomorrow at 5:00 PM CST.
Later guys.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-02-2005, 01:00 AM   #6
Also, if I forgot to list any dependencies, or it doesn't work,
please forgive me, as this is the first try at release
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-02-2005, 01:01 AM   #7
theheel is on a distinguished road
for the non technical idiots (me) what does this mean in laymens term? i read all that but it went over my head.
theheel is offline   Reply With Quote
Old 05-02-2005, 01:05 AM   #8
My Village Called
0l33l's Avatar
Its for developers. So expect to see more integrated development between developers
So it will be easier for me to talk to FP, and to the program that I am making. Also FP will be able to talk to my program directly, as well as with NaviVoice. Its a web basically
Also programs will now be able to ask others about what they are doing, etc...
Old 05-02-2005, 08:49 AM   #9
camsgs3 is on a distinguished road
yea im with you!
please explain that one, i didnt know IG can be skinned yet.....
camsgs3 is offline   Reply With Quote
Old 05-02-2005, 09:05 AM   #10
Maņana's Avatar
Maņana is on a distinguished road
Well, probably it can with help from this... Guess "skinned" means a sepparate skinnable program that controls and shows iG?
My carputer
Old one
Maņana is offline   Reply With Quote
Old 05-02-2005, 09:49 AM   #11
ohh so its somthing like the sendkeys in RR..we just need to make the dam OSK bigger & some menus
Old 05-02-2005, 10:59 AM   #12
Erorus's Avatar
Erorus is on a distinguished road
Any reason why you didn't just open a TCP port in your app and use XML RPC? What does FrodoComm add?
Erorus is offline   Reply With Quote
Old 05-02-2005, 11:04 AM   #13
This is not limited to XML, as well as being very easy to use and intuitive.
It's a network, not just a way to pass messages.
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-02-2005, 11:04 AM   #14
No, this is way more powerful.
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 05-02-2005, 11:41 AM   #15
sounds good, even though i have no idea how this all works
0l33l - looking foward to see what you can come up with IG
this stuff is very interesting, im assuming this was the part of the xxx you guys where talking about a couple of months ago
