The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > FrodoPlayer > FP Skins
Thread Tools Display Modes
Old 04-29-2005, 12:40 PM   #1
Phone Control Moderator
zorro's Avatar
Vehicle: 1998 Audi A3
My Photos: (0)
Need a skinning tool?
Look here: http://www.mp3car.com/vbulletin/show...629#post468629
Skinning to go... VisualDesigner2!
zorro is offline   Reply With Quote
Sponsored Links
Old 05-19-2005, 08:30 AM   #2
pijo1971's Avatar
Vehicle: Alfa 147 JTD
My Photos: (0)
hi to all,
excuse me if i don't understand, but with the tool you can build only the .jpg files or also the .ini files ?
thanks,
luigi.
pijo1971 is offline   Reply With Quote
Old 05-19-2005, 08:39 AM   #3
zorro's Avatar
My Photos: (0)
With the applied ExportProvider for FrodoPlayer it'll also make you a INI file with all information you need to run it in FP (hopefully )
Old 05-19-2005, 10:29 AM   #4
pijo1971's Avatar
My Photos: (0)
thank you for the answer, but i've again some difficult.
This is the procedure I've used:
1. I've installed PhoneCtl
2. I've extracted the Vdesigner.zip files into "...\PhoneControl.NET" directory
3. I've registered the VDFrodoPlayer.dll
4. I've launched the PhoneCtlDesigner in this way "PhoneCtlDesigner.exe -Other=FrodoPlayer"
5. I've designed my skin
6. I've saved my project into a "myskin.xml" file
7. I've used the "Export skin" function
8. Into "VisualDesigner Export" form I've choosed
provider: FrodoPlayer
picture format: jpg
9. The created files were:
myskin.xml
In this way no .ini files were produced, can you help me to solve the problem?
bye,
luigi.
Old 05-19-2005, 11:25 AM   #5
zorro's Avatar
My Photos: (0)
So far, you did everything right.
There is one setting you might have not done yet:
If you select (click) the background, you'll see a AdditionalInfo in the property grid.
Click the [...] button and add the following:
Section=Main
Autor="--you--"
Created= -- date --
If this is still not producing the myskin.ini, please let me know.
Old 05-19-2005, 01:38 PM   #6
pijo1971's Avatar
My Photos: (0)
good.. :-) it's working.
thanks a lot.
Luigi.
Old 05-19-2005, 01:41 PM   #7
zorro's Avatar
My Photos: (0)
Hope you show us your skin soon
Old 05-19-2005, 08:56 PM   #8
My Photos: (0)
Hello,
I have problemes with the installation.
Canīt register the dll (install= T:\Programme\PhoneControl.NET)
Can Anyone give me the right command?
How can I change a ready Skin for FrodoPlayer(ini -> xml)
Hope you can help!
Ti-ejtsch
Edit: Itīs very difficult to read and write in English, so please donīt laugh when you read my posts!
Ti-ejtsch is offline   Reply With Quote
Old 05-20-2005, 12:18 AM   #9
zorro's Avatar
My Photos: (0)
No one's laughing at you.
Open a new command line window on T:\Programme\PhoneControl.NET then enter
regsvr32 VDFrodoPlayer.dll
There's no way yet to convert a INI into the VD format. If you want to edit an existing skin, you have to remake it using the original background picture files.
For the main screen you could use the XML file I've created for testing.
Old 05-20-2005, 03:51 AM   #10
My Photos: (0)
Hi,
Thank you,
but I donīt know how to open a new command line in T:\..., I think I donīt understand what you mean.
Another problem is that your XML-file is for RoadRunner, so I donīt have the commands for FrodoPlayer. When I use the XML for PhoneControl I have not all commands, for example GPS!
Ti-ejtsch
Sponsored Links
Old 05-20-2005, 04:44 AM   #11
zorro's Avatar
My Photos: (0)
Copy the attached batch file into the installation directory, remove the ".txt" from the filename and execute it (by doubleclick).
There is a special Xml file for FP too... take another look into the thread.
File Type: txt register.cmd.txt (28 Bytes, 161 views)
Old 05-20-2005, 05:40 AM   #12
My Photos: (0)
@Zorro
Thanks a lot for the .cmd !!!! It runs perfect. Is it necessary to run the .cmd every time, when i want to work with VDesigner?
I think Iīm blind. I downloaded the Skin ( http://www.mp3car.com/vbulletin/show...629#post468629 )but I canīt find all commands for Frodoplayer (for example GPS)
Greetings from Germany
Ti-ejtsch
Old 05-20-2005, 06:25 AM   #13
zorro's Avatar
My Photos: (0)
No, you don't need to register it anymore.
I didn't implement all commands. Simply add them as needed or ask for someone who already did it.
Old 09-05-2005, 03:09 AM   #14
Meelobee's Avatar
Vehicle: VW GOLF Mk5.
My Photos: (0)
Can I use this to skin MapMonkey? (I want to change the OSK)
If I can use this, which files/programs do I need? I allready have downloaded PhoneCtlsetup1.4.6.zip but I can't find the VD update. It's supposed to be here: http://phoco.net/tmp/__Bin/VDesigner.zip but it says page not found.
[■■■■■■■■■■■■■■■■■■■■] Install 80%
WWW.ZDCLAN.NL
Meelobee is offline   Reply With Quote
Old 09-05-2005, 03:35 AM   #15
zorro's Avatar
My Photos: (0)
You can do this to make the graphics. But there is no ExportProvider yet that would let you make the skin.ini automatically.
VD is part of the PhoCo setup. So it's not longer available standalone (because it needs some components to be installed).
If you install PhoCo, you'll have it.
Sponsored Links
vB code is On
Trackbacks are Off
ColdHeat Soldering Tool! [iG] General Hardware Discussion 60 02-04-2005 08:11 PM
Skinning tutorial? erazor FrodoPlayer 26 11-06-2004 07:36 AM
PhoneControl XML files editing tool zorro PhoneControl 0 10-17-2004 06:25 AM
Is skinning FP as easy as Winamp ?? Don 944 LA FrodoPlayer 3 09-27-2004 09:52 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
