Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > FrodoPlayer > FP Skins
Old 10-01-2005, 04:55 PM   #31
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
I know I said that I'll be releasing two other brands (subaru, land rover) this weekend but I have some family problems.
I will try to work tomorrow and hopefully finish them.
Thanks for you support.
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 10-01-2005, 05:58 PM   #32
Zductive is on a distinguished road
am I the only one?
I am having two problems.
1 - Carweb -
How do you install carweb into two different directories like you show in your ini file. If I install it in one, it doesn't run in the other. If I copy carweb.exe to the other, it still doesn't run.
2- frodopictures
I don't know of any ini settings for this application.
When I click on it it says file not found or not configured.
If I change the ini information for pics to be what the plst is, then, frodopictures runs fine. It also runs fine in the tv spot. Are the settings for pics in the ini file correct? What should I do?
DVD and carweb run correctly.
Still looking for a 350Z or Fairlady Z logo. Will be glad to make my own after you release the psd.
Take your time. Family comes first!
Zductive is offline   Reply With Quote
Old 10-01-2005, 09:06 PM   #33
Para Laura
1.weird cus that is the way to do it..... install it pointing to the day folder and then copy all the files to night folder (then replace the .ini files and jpgs with the correst skin)
2.FrodoPictures doesn't exist in my skin.... you have to install PIC plugin by DragonBTV (check link in my 1st post).
Quote: Originally Posted by thanatos106
In order to post the PSDs I have to fix them cus there are a mess.
And to tell you the true I don't think I will be releasing them in a near future...... but the logos is really easy to do (I haven't forget about you) but I got this prob and like you said family is firts.
Thanatos.
Nissan Aux-in MOD
Old 10-02-2005, 11:47 AM   #34
chrisu02's Avatar
chrisu02 is on a distinguished road
I've another question, i don't know how much work it would be (don't know how to make skins ...)
Is it possible to move the volume control in to the lower left side? (like on the pic),
then probably the last and next track button have do move on the upper side (which are inmho not so necessary because a short touch on the fastforward butten does have the same function )
The reason is because now on the right upper corner it is a little bit more difficult to handle and the hand is very much on the passenger seat side
hope i don't annoy to much ...
greets Chrisi
chrisu02 is offline   Reply With Quote
Old 10-02-2005, 01:48 PM   #35
Para Laura
@Crisu02 maybe....
Hey I see in the shot that you guys don't have the right fonts for the skin (my bad )
Check first link under "RexBruMet main folder" to get them.
Thanatos.
Nissan Aux-in MOD
Old 10-02-2005, 06:58 PM   #36
dukman is on a distinguished road
cdrip ini
Can someone please explain how the skin on the cdrip is supposed to work. I realize that with RR it loads the skin automatically and i have tried several different ways but can't seem to figure out how to set it up.
dukman is offline   Reply With Quote
Old 10-02-2005, 07:06 PM   #37
Para Laura
What??
Ok you know that CDRip is a plugin right?? so the skin that I made for it, you just have to put it in the skin folder.... that it!
Thanatos.
Nissan Aux-in MOD
Old 10-02-2005, 07:29 PM   #38
Sorry but i guess i don't get something. When i run cdrip.exe it says that "C:\program files\cdrip\day\ does not contain a valid skin"
I was trying to find where to point it for your skin. I have the jpegs for the skin but i don't have the skin.ini to go along with the jpegs?
Old 10-02-2005, 07:32 PM   #39
Para Laura
Open C:\program files\cdrip\day\skin and tell me what files you see.
Thanatos.
Nissan Aux-in MOD
Old 10-02-2005, 08:20 PM   #40
The 7 different jpeg files that make up the skin
Thats all that was in the folder
C:\Main RexBruMet\Main RexBruMet\CDRip\Day
when I unzipped it.
Old 10-02-2005, 08:23 PM   #41
Para Laura
No!!!! you have to install the plugin.... refer to post one for the link.
Those are just the jpgs for the plugin no the whole thing.
Let me know if you still having questions about it.
Thanatos.
Nissan Aux-in MOD
Old 10-02-2005, 09:04 PM   #42
Yes, i understand the plugin concept-all the rest you have posted work fine.
I had the .exe and .dll's in the C:\Program Files\CDRIP\DAY and the jpegs in a sub dir C:\Program Files\CDRIP\DAY\SKIN
I changed it and moved the program files to C:\Program Files\CDRIP\DAY\SKIN
and got the same result?
What is the cdrip.ini file supposed to look like, mine is:
# Skin Path (If running from within RR this is obtained automatically)
# If left blank, the subfolder "Skin\" under the application folder is used.
#skinpath=<PATH>
I haven't changed it-this is the default setting.
Old 10-02-2005, 09:18 PM   #43
Para Laura
Ok did you download the default skin for CDRip?? (so you can overwrite the jpgs)
Because to tell you the true the thing is pretty easy:
Download CDRip descompress it in Day folder (same for night)
Download default skin descompress it inside CDRip folder, overwrite Jpgs with the ones in RexBruMet main follder\Cdrip.
Thanatos.
Nissan Aux-in MOD
Old 10-03-2005, 01:28 AM   #44
thank you
thank you very much. I was missing the original skin with CDRIP.SKIN OSK.SKIN and GENERAL.INI files.
if you would add those to your folder with the jpegs i think it would help people in the future. sorry i didn't understand but i have no knowledge of RR and never thought to look there for an original skin.
what you have added to frodo is amazing-kudos to you sir
Old 10-03-2005, 01:41 AM   #45
Para Laura
Thanks.....
I will make the changes so people don't have this prob in the future.
Thanatos.
Nissan Aux-in MOD
iGMod Beta 1 release PURDooM Other Cool Stuff 175 12-28-2005 11:17 PM
[SKIN]FPs "Bright Life" (input needed to complete) yunusyu FrodoPlayer 76 06-25-2005 03:59 PM
RELEASE - FreeDrive 0.60 CdRsKuLL FreeDrive 144 06-10-2005 05:45 PM
SpeakEasy Voice Recognition - Release 0.9.1 ruairi Software & Software Development 11 06-03-2005 06:19 PM
