06-08-2006, 03:29 PM
#1
Vehicle: 2003 Mitsubishi Eclipse GT, 5spd
I need a 600x800 skin!!
I want to turn my 800x600 screen sideways, but I NEED a 600x800 skin so I can still use FrodoPlayer!!!
Anyone have one? Hook me up, paaaaahhleeeeze!
So far:
M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
06-12-2006, 01:41 PM
#2
Do I need to say pretty please?
So far:
06-13-2006, 10:59 AM
#3
Vehicle: 1995 BMW E36
r u goin' to have portrait display like PDAs??
BMW E36 Project [ =======§== ]
Hardware:
Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
Software:
FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
06-14-2006, 07:45 AM
#4
I'd like to do the portrait display. But if I can't find a skin for it, I won't mount my monitor that way, and just use the landscape display. I think portrait would be better for GPS use, since you would see more of the road ahead of you, than to the sides.
So far:
06-14-2006, 10:24 AM
#5
Vehicle: 91 Ford Probe
Well, I'm sure you won't find a 600x800 skin. Why don't you make one yourself ?
06-14-2006, 10:39 AM
#6
Keep in mind u don't need a frontend skin only, but a gps skin too.... 'cause i think there's no skin actually made for a 600 width... OSK should not being displayed correctly...
Hardware:
Software:
06-14-2006, 02:42 PM
#7
Why not make one myself? Because I tried that and failed miserably. I guess I just don't get how to skin stuff.
I use FrodoPlayer and iGuidance. I should only need a skin for FrodoPlayer, since iGuidance just maximizes itself within the FrodoPlayer screen area.
There was mention in the early FrodoPlayer posts about a 600x800 skin, and it was kinda implied that it came with FrodoPlayer, but I can't find it. The only skin I got with the software was the 800x600 stretched for 800x480 skin.
So far:
06-15-2006, 06:22 AM
#8
Basically FP too maximize in a window area...
just change in FrodoPlayer.ini:
Code:
[ADVANCED]
ADV_TOP=0
ADV_LEFT=0
ADV_WIDTH=600
ADV_HEIGHT=800
and
Code:
USE_ADVANCED_SCREEN_SETTINGS=TRUE
Hardware:
Software:
06-15-2006, 10:50 AM
#9
Sweet! I'll try that when I get home. Maybe that's why there's no 600x800 skin - you don't need one.
Thanks again Frigor!
So far:
06-15-2006, 11:11 AM
#10
I tried it here at work, and it works. Things are stretched, and the aspect ratio is a bit screwy. But it works just fine. I really should try the new skinning tools and see if I can do any better (this time) with my own skin.
Frigor: would you mind if I used your skin to base mine from? I'm thinking all I would do is stretch things and maybe move a couple things around for a portrait layout.
So far:
06-19-2006, 11:31 AM
#11
If u are able to download the psd files u can edit anything u want to made your own skin... the suggest i give u is to take a skin (IMGs) rotate it and re-edit the ini files with some tool or simply using a text editor...
Good luck!
Hardware:
Software:
| Thread Tools |
| Display Modes |
Linear Mode
