Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain > Fusion Brain Innovations
Old 02-05-2009, 10:54 AM   #1
Civic Modz is on a distinguished road
eyeR Interceptor "MINI" MOD for the V3/V4 FusionBrain
UPDATED 6-NOV-09
Final board for the eyeR PRO complete with enclosure
Here are the two custom manufactured remotes:
Both remotes have unique code so they can be used at the same time without conflicting with each other.
  • "CLIMATE" remote is dedicated for HVAC systems.
  • "OUTPUT" remote can be used to independently control/intercept the 11 relay outputs,One PWM and one servo output can also be controlled.
Preliminary Specifications:
  • Slimline design, 70 x 48 x 14.5mm (with enclosure) so you can slide it in anywhere. Right angle connectors to reduce profile.
  • Lower Standby current, approx 2 - 5mA (when device is in sleep mode)
  • Can be used in conjunction with FusionBrain and other output devices if desired.
  • Stand alone operation, device will function before USB port/PC has powered up.
  • Up to 11 intercept-able outputs. On board intercept LED indicates when inputs do not match outputs.
  • On-board transient protection for automotive applications.
  • all inputs can accept 4-15v inputs (level conversion not required)
  • All Inputs/Outputs can be read/controlled via PC respectively.
  • On-board Infra-red receiver for controlling the outputs via remote.
  • 11 Direct relay outputs.
  • Low power mode with remote wake up for when the vehicle is turned off. IR remote control or inputs changes can wake up device.
  • Built in features such as auto engine start (with bulit in RPM monitor) turbo-timer and start-up/shutdown timers.
  • 2 dedicated Pulse width modulation (signal level PWM) outputs with up to 10-bit resolution, that's 1024 steps. This is useful for ultra precise motor/solenoid/dimmer control.
  • 2 Independent Servo drivers (direct connection) with on-board power supply ~6.5v for high torque operation.
  • Interception sampling rate can reach up to 5kHz.
  • On board 3-port hub for add-ons.
  • RS232 connection for communicating to other devices.
  • USB Drivers available for Windows and Linux 2.6.x and 2.4.36
  • eyeR and add-ons firmware easily upgradable over USB.
Civic Modz is offline   Reply With Quote
Old 02-05-2009, 12:25 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
That is pretty darn spiffy!
Old 02-06-2009, 08:06 AM   #3
RonS is an unknown quantity at this point
I am liking this. The only thing I would like to see are 2 servo outputs. I need 2. One for heat control and one for heater/defroster control. But that is just me. Keep up the good work.
RonS is offline   Reply With Quote
Old 02-06-2009, 08:26 AM   #4
I will look into a second servo connection. The only thing is that one servo can be directly connected to the board, If two servo's are required I could possible make a splitter cable that enable you to connect two servo's.
I will let you know soon if I can manage to squeeze in an extra connection for the splitter cable.
Saying that it also possible to add additional servo ports using an add-on that plugs into the drive-by-wire bus.
Old 02-11-2009, 08:58 AM   #5
Rick99TAWS6 is an unknown quantity at this point
Very interesting - second servo would be great
If anyone gives me a rev - I give them the Bird
Rick99TAWS6 is offline   Reply With Quote
Old 06-05-2009, 02:45 AM   #6
keyvan's Avatar
keyvan is on a distinguished road
Is there any way to use the PWM to control a HIGH CURRENT motor, like for an electric vehicle's throttle control?
Thanks,
Keyvan
1997 Mazda Miata, Black
MiataPC
In-dash Fabrication
Current dashboard: http://www.aescarpc.com/miatapc/2
keyvan is offline   Reply With Quote
Old 06-05-2009, 07:36 AM   #7
From my understanding, the accelerator is basically like a variable resistor (fast & accurate A/D sampling required) and the throttle is controlled via a stepper motor. The eyeR can sample A/D but I havent tested how fast/reliable and accurate. The eye does a/d sampling, has the potential to drive stepper motors and high current motors (with the use of the PWM FET module addon)
So yes, the eyeR is capable.
Old 06-30-2009, 01:20 AM   #8
2k1Toaster's Avatar
Any updates?
Old 07-04-2009, 05:30 AM   #9
Thanx for the interest,
I know its been a while since a last update.. I have just sent the first batch of PCB's for manufacture. So I hope to have a finished product working in about 2 weeks.
A little board modification (for an enclosure allowance) and slight component modification needed to be done.
Old 07-04-2009, 12:37 PM   #10
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
This could be the worst question in the world, but what does this thing do? I read it back when it first came out and I read it again today. Am I the only one?
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 07-05-2009, 09:11 AM   #11
Hmm, I don't think there is such a thing as the "worst" question!
To answer you question, the first version of the eyeR interceptor was basically to intercept/control the fusion brain outputs while the PC/fusionbrain was off.
for example, say one of you FB outputs was connected to a relay and suddenly your PC shutsdown or wont boot up! How can you control this relay with the FB not working? (since it requires the PC to be on for it to function) If you connect one of the eyeR inputs/outputs in series with this connection, you will be able to take control of this relay again with the use of an IR remote or any RS232 interface, since the eyeR does not need a constant PC connection in order to function.
This system can come in very handy for a complete HVAC system which needs to be controlled when the PC fails (say to demist the windows).
Though, initially the first version (FB piggy-back) was specifically designed for HVAC systems, the next model has a host of new features/capabilities such as more dedicated PWM and servo outputs, intercept only mode, direct 2-15v inputs (no need for bias resistors) and a drive-wire bus system which allows countless add-ons to be added.
What are these add-ons?
Well, I don't want to reveal all of them just yet but the one i'm working on now is the RF Transmitter which allows you to have wireless control of mains and 12v devices directly through the FB/eyeR. Just imagine a RF universal remote!
Old 10-05-2009, 12:30 PM   #12
hans14914 is an unknown quantity at this point
Any more news on this product?
Hans
hans14914 is offline   Reply With Quote
Old 10-06-2009, 06:24 AM   #13
The "blue" version (eyeR Mini) was tested and I decided to add a 3 port hub for the add-ons and made a few little hardware changes.
The new version (now black!!.. i know) is a bit bigger and board has been modified for an enclosure. I actually just received the black (final) boards today but still waiting on some back order components.
The two custom IR remote controls have already been produced and now just working on a VB app to configure the device.
So there is still a few weeks before release, though I might have to release a limited amount of units before then for a test release and then update firmware as required.
I should update my first post soon with what I have done.. I will do this soon
Old 10-06-2009, 10:52 AM   #14
Thanks for the update. Do you have any documentation ready on the new board? I am very interested to see if I can use the built-in climate program with my cars climate system.
Hans
Old 10-07-2009, 07:49 AM   #15
No complete documentation at the moment. Though if you can share a pic and a some info on how your climate works, eg cable driven, electronic or pneumatic. Then maybe I could help.
eyeR MOD for the Fusion Brain, add PWM, Servo and remote control. (eyeR Interceptor) Civic Modz Fusion Brain Innovations 17 01-16-2009 10:48 AM
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 03:59 AM
FAQ Tutorial: Wire/Pin Mod for Mobile Athlon Quattro The FAQ Emporium 25 05-06-2006 01:50 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
