Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 11-15-2007, 08:59 PM   #1
Input and Output configuration questions
I thought I'd un-bury these questions from the AC tread, I don't know if it will get answered otherwise:
Input Question:
Inputs have three leads: low ref, high ref, and sensed right?
Is the low ref side the same as ground?
Can I leave sensor low reference disconnected from the board and connect it to gnd somewhere else if I plan to use that path as a return path for current from a servo motor as well as sensor low reference?
Will that affect sensor reading at the middle terminal?
See http://www.mp3car.com/vbulletin/1141485-post8.html for context.
Output question:
Can I tie the + side of several digital outputs together, I would assume it would be fine, and that the + side of the outputs (the non transistor side) comes from one place anyway, but I thought I'd ask.
Then again, it's not like I can get these things to work on my computers anyway
h3rk is offline   Reply With Quote
Old 11-15-2007, 10:50 PM   #2
Fusion Brain Creator
all three wires should be run back to teh fusion brain. we sell 3 pin extensions for this.
you can tie together the + side. ground is switched.
greenman100 is offline   Reply With Quote
Old 11-15-2007, 10:51 PM   #3
bad news for me. how much current can the low side take?
Edit: Enough for a servo motor's drive current?
Old 11-16-2007, 02:24 AM   #4
There, I bought some 3 pin extensions, are you happy now?
I guess I'll have to hack the servo and seperate the two circuits, pre brain....thanks for the info.
Kenwood Nav input & touchscreen output port20 LCD/Display 89 09-03-2008 11:38 AM
Optical Input To Rca Output Converters! Crazystick Car Audio 18 01-06-2006 03:51 AM
Alpine NVE-N077PS's RGB output to VGA input on 7" lilliput TS monitor? hsuca GPS 3 10-04-2004 05:13 PM
Alpine NVE-N077PS's RGB output to VGA input on 7" lilliput TS monitor? hsuca LCD/Display 0 09-27-2004 07:07 AM
