The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Thread Tools Search this Thread Display Modes
Old 11-24-2007, 02:28 PM   #1
Vehicle: '06 350z
My Photos: (0)
Can Fusion Do this?
Ok so another "Can Fusion do this for me?"
I want to setup temperature controlled relays. So my CarPC, Screen wont power up until it hits a specified temperature. Can the fusion do this with a temp sensor.
Im not sure if it can work independately of the carpc or if the brain is basically useless until windows is booted?
Cheers
SKiTLz is offline   Reply With Quote
Sponsored Links
Old 11-24-2007, 02:45 PM   #2
h3rk's CarPC Specs
Vehicle: 2006 Nissan Altima
My Photos: (0)
From what I understand, the brain is basically useless until windows is booted. There are delays that can be set to turn off outputs later, after shutdown. But that's not really going to help you.
h3rk is offline   Reply With Quote
Old 11-24-2007, 04:13 PM   #3
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Yup, right now the Brain is useless until the PC boots. But you can get the PC to boot, and then turn on the screen.
Old 11-24-2007, 04:22 PM   #4
Vehicle: '06 350z
My Photos: (0)
Ok makes sense.. So it will half work for my situation..
With that said.. Does the fusion software run as a service?
Old 11-24-2007, 04:27 PM   #5
2k1Toaster's Avatar
My Photos: (1)
You can set it to startup on windows load just as you can do with RoadRunner and other programs. And there are default states, so once the computer boots, it loads the programs, it sends commands to the outputs for the default state.
Old 11-24-2007, 04:34 PM   #6
h3rk's CarPC Specs
My Photos: (0)
That usage would fit in well with the rear camera-A/V select function usage someone was talking about in the big thread, way back when.
Old 11-24-2007, 05:11 PM   #7
Vehicle: '06 350z
My Photos: (0)
Ok thanks. But does it run as a Startup Application or a service? before logon or after in otherwords.
Old 11-25-2007, 07:37 AM   #8
h3rk's CarPC Specs
My Photos: (0)
I'm sure I don't know enough to have an opinion on the matter, but why would one have a need for it to run as a service?
I cant imagine a carPC with different accounts and the need for a user logon. How much time would it buy to have it start with the system services?
Is there another benefit?
It seems that when windows introduced the delayed start-up, they were recognizing that too many services starting up at the same time was a problem.
I guess having the screen available asap is a nice thing though.
Old 11-25-2007, 01:05 PM   #9
Vehicle: '06 350z
My Photos: (0)
More a time thing for me.. I know anything i run as a service on my CarPC starts at ;east 2-seconds earlier than the rest..
Its not a huge deal i was just curious..
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
*NEW* USB Input/Output Board -- Fusion Brain 2k1Toaster Fusion Brain 1095 08-04-2008 01:22 PM
Skin Direction, Help.. Fusion Brain Integration Also. Ryann RR Skins 5 10-22-2007 08:40 PM
Win $25 for designing the best skin for the Fusion Brain's Software! 2k1Toaster Skins 66 10-20-2007 02:25 AM
using fusion brain to delay turn on of amp theheel Fusion Brain 9 08-27-2007 09:33 PM
Fusion Brain Integration michael2 RR Plugins 2 08-21-2007 11:59 PM
Sponsored Links
Ad Management by RedTyger
