The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Thread Tools Search this Thread Display Modes
Old 01-31-2008, 04:11 PM   #1
Vehicle: Range Rover HSE 1995
My Photos: (0)
Question INPUTS - 12V Volts <> 5 Volts
Is this correct:
If you supply a voltage creater than 5V to board you will damage it?
If you what board to act as voltmeter, must you use a Voltage Divider to ensure the max input doesnt exceed 5V - does the brain then convert and display 5V as being full battery charge?
FusionFormDynamic.skin doesnt show any processing?
#STARTNEW#
#NAME#Battery
#TYPE#VOLTAGE
#VIDPID#MyBrain0
#MULTILEVELGRAPHICS##0,4.3#\Black Skin\Analogue Graphs\Battery\Bar0.png;\Black Skin\Analogue Graphs\Battery\Bar1.png;\Black Skin\Analogue Graphs\Battery\Bar2.png;\Black Skin\Analogue Graphs\Battery\Bar3.png;\Black Skin\Analogue Graphs\Battery\Bar4.png;\Black Skin\Analogue Graphs\Battery\Bar5.png;\Black Skin\Analogue Graphs\Battery\Bar6.png;\Black Skin\Analogue Graphs\Battery\Bar7.png;\Black Skin\Analogue Graphs\Battery\Bar8.png
#SIZE#92,144
#LOCATION#133,19
#SHOWTEXT#false
#PAGE#0
#PORT#1
#BORDERSIZE#0
#PLOTLENGTH#100
#HISTORYSIZE#250
#ENDNEW#
thanks peter
vultan is offline   Reply With Quote
Sponsored Links
Old 01-31-2008, 10:53 PM   #2
Fusion Brain Creator
My Photos: (0)
I will reply to the hardware portion, Nick can reply to the software scaling.
If you source more than 5vDC to the analog input, you will damage the PIC.
The easy solution is a voltage divider.
The better solution is an Op-Amp.
Both are available with examples on Wikipedia.
greenman100 is offline   Reply With Quote
Old 01-31-2008, 11:00 PM   #3
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
I dont understand your software question...
Old 01-31-2008, 11:29 PM   #4
My Photos: (0)
i think he wants to know how to scale voltage inputs
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
How-To: Modifying the PW200 evandude Power Supplies 13 08-18-2005 06:45 AM
Opus 120w wiring help.. 2 ground and 12v inputs?? jedi7001 Power Supplies 6 06-13-2005 12:51 AM
M1-ATX and heavy 12V rail miki Power Supplies 6 05-13-2005 07:18 AM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 09:31 PM
Possible Solution for Dual Sproggy 12V @ 10A mp3z24 Power Supplies 5 07-10-2003 12:33 PM
Sponsored Links
Ad Management by RedTyger
