04-05-2008, 08:51 PM
#1
Vehicle: 2000 Protege
Possible to show both F and C for temp at the same time?
For a single Sensor.
Great hardware/software solution guys. Also looking forward to the Com integration for RoadRunner.
Kinda like this:
72.125 F
26 C
or
72.125 F/26C
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
04-06-2008, 01:29 AM
#2
Fusion Brain Creator
Vehicle: 2001 Honda Civic EX Coupe
Kinda like this:
72.125 F
26 C
or
72.125 F/26C
The top is very doable with 2 different variables going into a label. Them in the same label is different... It is something I will look into getting to work.
04-08-2008, 12:17 AM
#3
So you were saying the first is doable, how do I put two variables in a single Label from a single sensor? just duplicate the #SETTINGS# in the same #STARTNEW# But with different variables?
Here is a nice screenshot of my Brain and temps working fine in RoadRunner btw. Will install in the car on the weekend, all seems working, all systems GO.
Carputer
Sound Stage
04-08-2008, 01:21 AM
#4
are you just skinning our software inside RR?
Also: I think Nick's advice was foer MDX, not Ver 2.0
04-08-2008, 09:12 AM
#5
Yep skinning until the dll is available that supports COM, this is a good interum solution. MDX maybe an issue for those of us with Intel "Little Valley" boards as they only support direct x 7. But going to try and install Direct x 9c had hope it simply does not take advantage of the more complex graphic features.
So is there a way to show both C and F for one variable and one sensor under the old ver. 2 software?
Carputer
Sound Stage
04-08-2008, 11:18 PM
#6
Version 2 no.
MDX, sort of. The way you have it now, is what can be done in MDX currently. But I will add a text label that allows for variables in any order/style you want, and this will not be added into Version 2.
04-09-2008, 09:51 AM
#7
Thanks! Panda, err bear, errr raccoon, err furry thing.
Carputer
Sound Stage
| Thread Tools |
| Display Modes |
Linear Mode
