04-27-2008, 05:04 PM
#31
Vehicle: 2000 Protege
If someone could help check out my FusionConfiguration.xml posted below that would be GREAT. No go on the mulit image archy looking images. I am so close now.
I have a single temp sensor on port 0. Used all the graphics included in the update. Background and static inside temp graphic shows. I did the logic, variables, inputs etc. I bet its something wrong with my settings of one of those.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
04-27-2008, 05:22 PM
#32
Fusion Brain Creator
Vehicle: 2001 Honda Civic EX Coupe
Quote: Originally Posted by Avid
^^^ awesome, thanks!
However, you said to make the variable numeric but it wont let me connect a non-boolean module to the output of an if/then node. am i doing something wrong?
If you are using a set variable, you do need the newest version of the configurator (or a week old at most) since I had a bug there.
Just click update on the MDXUpdater and it will download.
04-27-2008, 05:24 PM
#33
I will try to take a look at it tonight, but right now it is crunch time for school work so I am swamped...
05-04-2008, 03:51 PM
#34
any updates?
Carputer
Sound Stage
05-04-2008, 03:55 PM
#35
any updates?
no. I still have a lot of homework to get done by this week. Then its final exams. Then I will be free.
05-04-2008, 04:09 PM
#36
Ok, just d/led it and took a look. First thing saw is display size is 0,0
It will never display the multiimage.
05-04-2008, 07:43 PM
#37
It's ok, ill check back in a week or two, get good marks on those zammies. No rush.
Carputer
Sound Stage
05-05-2008, 01:07 PM
#38
he means your skin file is wrong, fix the display size, and that'll help
05-11-2008, 03:36 PM
#39
Tried it, nothing yet, at least thats one issue out of the way.
Carputer
Sound Stage
05-11-2008, 03:38 PM
#40
So your changing of the size did nothing? Still cant see them?
05-11-2008, 05:16 PM
#41
You have the multiimage monitoring a variable. Your images are from between 65 and 85 inclusive.
Your variable is set to 5. Set it to 70 or something and delete the logic part. See if anything shows up.
If it does, then the logic section is wrong. First thing I would check is that the functions are where they say they are.
Your file looks fine to me other than that and the display size.
| Thread Tools |
| Display Modes |
Linear Mode
