04-06-2008, 06:05 PM
#1
Vehicle: 2008/Scion/Xb
Question for the creators
hey man,
I just now are getting ready to program the FB. I was wondering a few things.
Is there a way that I can program like a "demo" feature on the FB so when I'm at shows I can select that and have the front left lower, front right raise, back left raise, back right lower.
if I want to control cathodes, what do I need? a cathode needs 12Volts. also I'm looking to control an actuator also.
Also, how can I make the air ride fill as soon as the carpc is turned on? or do I have to wait till windows boots up to have MDX startup?
steve
04-06-2008, 06:21 PM
#2
Fusion Brain Creator
Sure. Are you using Version 2.0 or MDX?
You need a relay for each device. Cathode or actuator, same thing as long as the load is under 25 amps.
04-06-2008, 06:25 PM
#3
how do I know what version I'm using?
04-06-2008, 06:35 PM
#4
does your configuration file end in .skin or .xml?
04-06-2008, 07:10 PM
#5
xml but to wich question does that answer??
04-06-2008, 07:20 PM
#6
That means you're using Version MDX. Nick will be along shortly to help you with it specifically - again, I just do hardware.
04-06-2008, 07:23 PM
#7
I know thanks for the quick response, again.
04-06-2008, 11:36 PM
#8
Vehicle: 2001 Honda Civic EX Coupe
Quote: Originally Posted by dasaint80
hey man,
steve
Hi.
For your demo you want basically an "animation" or a set sequence of movements when the button is clicked to show off the various options correct?
If so yes this is doable with MDX which is the version you are using (configuration ends in *.xml)
The Fusion Brain does not work independantly from the PC. So once the PC boots, there is a default state for the MDX program that is settable. So as soon as the PC boots and MDX loads, it can turn on the relays for you and fill it up. With a properly optimized system this can be 10 to 20 seconds. Standby is obviously faster.
04-06-2008, 11:55 PM
#9
with the new Version(.skin) what's the difference? also where can I find a simple definition of each actions? for both old(*.XML) and new (*.skin)?
I want this cause I have very very very basic C++ programming. I have some VB and alot HTML....
Just trying to stay ahead for any future configs I might want to do.
Steve
04-07-2008, 12:05 AM
#10
you have it backwards. MDX is the newest and uses xml. Version 2 is almost not supported anymore and uses the skin file.
04-07-2008, 12:07 AM
#11
Steve
old is .skin, new is .xml
04-08-2008, 01:03 PM
#12
Quote: Originally Posted by 2k1Toaster
Hi.
How do I start this "animation" sequence?
What code sequence am I looking for?
Steve
P.S. you got PM.
04-09-2008, 05:02 PM
#13
^^^^bump^^^^
04-09-2008, 10:38 PM
#14
Sorry I saw this, but I forgot to answer.
Basically create a variable and set it to 0. Have a logic saying, varaible = variable + 1. Then another logic saying if variable is greater than x where x is the number of frames you want, then variable = 0. This will make the variable go 0,1,2,3,4,...x,0,1,2,...
Then make 1 logic for each number from 0 to x [n], and say if variable equals n, and attach to an output. In this logic's do then statement, add what you want to happen like trigger digital outputs or something.
Also we do custom skinning for $20/hr, but this is not possible at the moment as both Tim and I are very busy. If it is an emergency we can work something out.
| Thread Tools |
| Display Modes |
Linear Mode
