Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 06-24-2008, 11:42 PM   #46
Woofnstuff's Avatar
i'm looking forward to it arriving.. all that i really need, could be done with a few components and a relay or two, but this seems more fun.
Woofnstuff is offline   Reply With Quote
Old 06-25-2008, 03:27 AM   #47
How long are we looking at for the v2 board? I almost bought a V1 yesterday but will hang on now
monzablue16v is offline   Reply With Quote
Old 06-25-2008, 09:55 AM   #48
Fusion Brain Creator
2k1Toaster's Avatar
Somewhere between "a while" and "in the not so distant future".
After improving the PCB design, we have to build, test, and review. Then make changes if neccessary and build, test, review again and then if it works 100%, you can buy it.
We will keep support of the Version 2 (Green hand soldered beta board) and Version 3 (Current production) boards even as we will sell this new one.
Old 08-07-2008, 04:41 PM   #49
Any update on when the new FB will be available?
Thanks,
Dan
Dan2008 is offline   Reply With Quote
Old 08-14-2008, 10:01 AM   #50
With help from Rowan, we've finalized the design, and are awaiting a quote from our manufacturer.
greenman100 is offline   Reply With Quote
Old 08-14-2008, 11:37 AM   #51
Wow, it's so ... beautiful.
7cm x 4cm eh, reminds me of a MiniPac haha
colin is offline   Reply With Quote
Old 08-15-2008, 03:06 AM   #52
look so good man! im going to in for a new one before even installing my first one lol
Ryann is offline   Reply With Quote
Old 08-17-2008, 10:19 PM   #53
The new layout looks nice. The feature requests I have are more firmware related. Here are my ideas:
If the board is disconnected from the computer (doesn't receive an update after some time), can all digital outputs revert to their default state of off.
If the PIC crashes (due to bad power), can a watchdog be put in place to reboot the PIC?
Is there any possibility of doing a PWM output on some or all of the digital outputs?
mx270a is offline   Reply With Quote
Old 08-19-2008, 10:50 AM   #54
I have a hardware request. Is there a way we can get 12volts out on the outputs? If you are still using ULN2003's it would be easy. You could even put a jumper in and select 5 or 12 volts.
RonS is offline   Reply With Quote
Old 08-19-2008, 11:07 AM   #55
ULN2003's eh?
It seems that the setup you guys use is very similar to mine!
I created a board that uses a PIC18F4455 and 2x ULN2003 for the outputs.
Then there's a few analog and digital inputs that have no circuitry between them.
Good stuff, I know I did something right now
Old 08-19-2008, 12:12 PM   #56
the outputs have always used 12 volts, and will continue to do so....
Old 08-19-2008, 04:49 PM   #57
Oh Ok. For some reason I was thinking that they were 5 volt. I guess I should have measured them. Sorry about that.
Old 08-21-2008, 10:34 PM   #58
Woofnstuff's Avatar
just a suggestion, i see you have a label on the board now for the analogue inputs,
is there a pin one ID somewhere? and is pin 1 the +5v or the input +
something more like this perhaps?
the sensors supplied with the FB have the red (+5v) as pin 1, and putting them in backwards (towards what is labelled on the current FB pin 1) makes them go a bit hot
Old 08-21-2008, 10:48 PM   #59
2k1Toaster's Avatar
Attachment 51274
Notice the +, -, AN... That is what they are there for. You actually put your text over it.
And it is also in the hardware manual which is which for the current version. Red on the sensors is and has always been +. Connecting backwards not only makes the sensor hot, but can destroy your sensor.
Old 08-21-2008, 10:53 PM   #60
Woofnstuff's Avatar
i know i put my text over it...
was suggesting more descriptive labels thats all
that would wire it backwards on the above yes?
make it more dummy proof...
Integrate fusion brain commands into road runner buttons scotty562 FB Software 15 09-22-2008 08:02 AM
*NEW* USB Input/Output Board -- Fusion Brain 2k1Toaster Fusion Brain 1095 08-04-2008 01:22 PM
New Fusion Brain, other hardware greenman100 Fusion Brain 5 02-17-2008 08:15 PM
Skin Direction, Help.. Fusion Brain Integration Also. Ryann RR Skins 5 10-22-2007 08:40 PM
Fusion Brain Integration michael2 RR Plugins 2 08-21-2007 11:59 PM
