The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Thread Tools Display Modes
Old 04-10-2008, 12:49 PM   #1
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
couple of easy questions before car install in the weekend
Is it ok to cut the temperature sensor wire in half then run wire for length? Are the extensions for if you have your own sensors? Never worked with sensors before so want to make sure.
One other quick question, I am assuming the black wire with white stripe on the barrel connector is positive? Just want to make sure, I dont trust my meter skills.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Sponsored Links
Old 04-10-2008, 12:59 PM   #2
Fusion Brain Creator
My Photos: (0)
and a couple easy answers:
You can cut the wire in half. However, if it's not properly shielded, you run a risk of picking up noise.... so basically, YMMV.
White stripe wire is positive. Even if you hook it up backwards, nothing should blow up... the power regulator will get real hot and the power LED won't light.
greenman100 is offline   Reply With Quote
Old 04-10-2008, 01:24 PM   #3
-zip-'s CarPC Specs
-zip-'s Avatar
My Photos: (1)
sweeeeeeet thanks Mr. Green
Carputer
Sound Stage
Sponsored Links
vB code is On
Trackbacks are Off
clear up a couple of questions dmx21 Newbie 3 07-12-2007 09:11 PM
2007 Mustang Install (first car pc install) Hessian Newbie 14 06-28-2007 07:44 PM
Answer to all your car's needs : never loose your car again! Romeo Input Devices 19 10-26-2005 11:53 PM
Car Comp 2 project starting soon! Questions... JBCrash General Hardware Discussion 19 05-04-2005 04:10 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
