The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Thread Tools Display Modes
Old 04-14-2008, 11:22 PM   #1
kelmk's Avatar
Vehicle: 2002 BMW 330ci vert
My Photos: (100)
alternative to obdII?
Is it possible to use a fusion brain to get data from the speed and RPM gauges? I am wondering if I can use this instead of obdII which updates way to slow to use as a digital dash.
I assume it is possible so could I display this data in an analog gauge style with the FB software?
kelmk is offline   Reply With Quote
Sponsored Links
Old 04-14-2008, 11:27 PM   #2
Fusion Brain Creator
My Photos: (0)
It is possible, but you would have to devise a circuit to convert the data to a 0-5 volt signal.
greenman100 is offline   Reply With Quote
Old 04-17-2008, 11:09 AM   #3
jimp's CarPC Specs
Vehicle: 2007 Chevrolet Impala LT
My Photos: (2)
Just curious as to what you might be using to interface your obd with? I use an elm327 through the serial port and I have no issues what so ever with the speed of it. I use palmer performance's dash command software in which I built my own dash board including a speedometer, tach, MAF, Coolant Temp., Voltage, and Intake Air Temp., all of which I display both with analog sweep gauges and digital readouts. It functions without any problems, and since my stock dash is useless in combination with my tilt wheel and driving habits, I really rely on it.
jimp is offline   Reply With Quote
Old 04-17-2008, 11:18 AM   #4
kelmk's Avatar
My Photos: (100)
I use a usb elm327 and using pcmscan demo which only shows rpm I get around 5 fps.
Other obdII software gives me around the same frame rate. I haven't tried dash command since the trial won't let me use real data, only simulated.
Old 04-17-2008, 11:26 AM   #5
jimp's CarPC Specs
My Photos: (2)
well I wont tell you that this is the best solution for you, but I was so impressed with the dash command program that I went ahead and purchased the pcmscan program also, I never looked at frame rates or anything, but for real world use I find no problems at all. you might get on their forums and ask brian about your concerns, but for me this solution works very well.
how are you interfacing the elm, usb, serial, bluetooth?
nevermind i see you said USB above
Sponsored Links
vB code is On
Trackbacks are Off
OBDII for ELM323 hjcho616 Road Runner 5 11-29-2007 09:14 AM
New Centrafuse Update, manual install with Debug OBDII version for testing veetid Centrafuse 22 04-15-2007 09:38 PM
OBDII Signal Splitter (for Infiniti G35) Caelric Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-14-2007 08:32 PM
Italian translation for RC4.5 veetid Centrafuse 0 01-05-2007 08:56 AM
OBDii on non-US cars ramy_zohair Engine Management, OBD-II, Engine Diagnostics, etc. 3 11-16-2005 01:30 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
