The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Thread Tools Display Modes
Old 04-17-2008, 10:54 AM   #1
jimp's CarPC Specs
Vehicle: 2007 Chevrolet Impala LT
My Photos: (2)
2 wire sensors
This is a stupid question that I should know the answer to but bear with me as I have spent as many years trying to forget this stuff since retiring than I spent learning it. In an automotive application you typically have 2 wire and 3 wire sensors, 2 wire sensors like thermistors for measuring temperatures are common. your temp sensor is a 3 wire sensor which makes it easy to hook up to a board that is set up for 3 wire analog inputs, but just the same, a 2 wire temp sensor is an analog input also.
Now if I wanted to utilize my already present ECT sensor can I just use the 5vdc and sensor return, disregarding the GND, or do I need to build some other circuit to interface it?
jimp is offline   Reply With Quote
Sponsored Links
Old 04-17-2008, 01:52 PM   #2
Fusion Brain Creator
My Photos: (0)
http://www.mp3car.com/vbulletin/docu...uspension.html
the fusion brain senses voltage, 2 wire sensors are variable resistance so they must be wired as part of a voltage divider
greenman100 is offline   Reply With Quote
Old 04-17-2008, 02:51 PM   #3
jimp's CarPC Specs
My Photos: (2)
So looking at the schematic you provided in the link then my 2 wire resistive sensor would go between the GND and the Input terminals on the brain and the 5vdc terminal would connect to a resistor of which the other end would tie in with the input terminal right?
also is the value of R1 a constant or is this going to be something that depends on the resistive range of the thermistor and if so is there a formula to determine the proper value?
Old 04-17-2008, 04:00 PM   #4
My Photos: (0)
"also is the value of R1 a constant or is this going to be something that depends on the resistive range of the thermistor and if so is there a formula to determine the proper value?"
the latter, and you can certainly optimize, but a nice rule of thumb is R1 = highest resistance the sensor can be
Old 04-17-2008, 06:06 PM   #5
jimp's CarPC Specs
My Photos: (2)
So if I have a thermistor that reads roughly 13k at ambient temp and 60k at freezing, I should be able to replace R1 with a 100k pot and adjust that to get the most accurate temp readings across the range I will be using and then replace it with a resistor valued approximately at the resistance I find with the pot?
Old 04-17-2008, 06:46 PM   #6
My Photos: (0)
yup, that'd work
Old 04-19-2008, 09:36 PM   #7
jimp's CarPC Specs
My Photos: (2)
just one other problem, what if my thermistor is a negative temperature coefficient device?
Old 04-19-2008, 11:15 PM   #8
My Photos: (0)
why is that a problem?
Old 04-19-2008, 11:32 PM   #9
jimp's CarPC Specs
My Photos: (2)
because as the temperature rises the voltage goes down. with room temp I show about 60 degree F, if I stick the thermistor in ice water It jumps to 125!
Old 04-19-2008, 11:37 PM   #10
My Photos: (0)
how are you converting to temperature?
it's not a problem, you just need a new formula to convert to temperature, utilizing the negative coefficient
Sponsored Links
Old 04-19-2008, 11:45 PM   #11
jimp's CarPC Specs
My Photos: (2)
#SETTINGS#((((($t$ - .4) * 1000) / 19.53) * 1.8) + 32)|t=VINC[!]
thats in the old program, tried the new configurator but haven't yet got it figured out, I get no multiimage showing and if I include the text label display, when I first fire up MDX it shows some reading but just jumps to "0" and stays there when its fully loaded.
Sponsored Links
vB code is On
Trackbacks are Off
Question for Zootjeff, What's the DSATX white wire for? greatwhite Power Supplies 2 10-21-2007 12:18 PM
Opus ignores ignition wire, constantly stays on Sham-Mobile Power Supplies 1 08-26-2006 06:28 PM
Question about wire to connect to battery thanassius Power Supplies 7 08-07-2006 10:35 AM
Totally dissapointed with my carputer! Maheriano General MP3Car Discussion 113 07-16-2006 08:26 PM
Pseudo-FAQ: What Do I Need For A Carputer? Maheriano General MP3Car Discussion 18 07-03-2006 02:04 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
