The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Thread Tools Display Modes
Old 04-26-2008, 11:07 PM   #1
jimp's CarPC Specs
Vehicle: 2007 Chevrolet Impala LT
My Photos: (2)
Variables to trigger outputs
Well it seems like I should have a grasp on this by now but I still can't make it work. it is odd because I have 2 outputs one controlled through logic by a thermistor connected to an analog input, and the other controlled through logic by a variable connected to a button.
the temp controlled one works flawlessly, but the variable controlled one, well I can turn it on but I cant seem to turn it off.
the logic is almost identical in both circuits, for the temp one I have
if input9 = 2.35 then trigger output1 on
and
if input9 = 2.40 then trigger output1 off
i can hold the thermistor between my thumb and finger and in seconds the output comes on, then seconds after I release it the output shuts back off
for the variable one I have
if variable1 = 1 then trigger output0 on
and
if variable1 = 2 then trigger output0 off
I can click the button and the the output comes on, but when I click it a second time the output stays on.
I am watching the variable change as it should in the debugger window but the logic doesn't trigger the output back off. I had another then statement that also changed the variable back to "0" and that worked also, I removed it to simplify things, so it is like the logic is working for everything except shutting off the output.
i have tried all priorities up thru absolute, to no avail. all my timers are set to 100 and seem to be working for the rest.
here is my logic ;
Code:
<!-- Begin Logic Declarations --> <all_statements> <if fire_on="logic"> <boolean_operation type="less than or equal to"> <parameter1> <analogue id="Port9" time="0"></analogue> </parameter1> <parameter2> <number>2.35</number> </parameter2> </boolean_operation> <then> <do function="Trigger Output" functionTargetID="Digital Output 0" vote_opinion="On" vote_priority="Low"></do> </then> </if> <if fire_on="logic"> <boolean_operation type="greater than or equal to"> <parameter1> <analogue id="Port9" time="0"></analogue> </parameter1> <parameter2> <number>2.4</number> </parameter2> </boolean_operation> <then> <do function="Trigger Output" functionTargetID="Digital Output 0" vote_opinion="Off" vote_priority="Low"></do> </then> </if> <if fire_on="logic"> <boolean_operation type="equal to"> <parameter1> <variable do="get" name="My Variable1"></variable> </parameter1> <parameter2> <number>1</number> </parameter2> </boolean_operation> <then> <do function="Trigger Output" functionTargetID="Digital Output 1" vote_opinion="On" vote_priority="Low"></do> </then> </if> <if fire_on="logic"> <boolean_operation type="equal to"> <parameter1> <variable do="get" name="My Variable1"></variable> </parameter1> <parameter2> <number>2</number> </parameter2> </boolean_operation> <then> <do function="Trigger Output" functionTargetID="Digital Output 0" vote_opinion="Off" vote_priority="Low"></do> </then> </if> </all_statements> <!-- End Logic Declarations -->
jimp is offline   Reply With Quote
Sponsored Links
Old 04-27-2008, 01:25 PM   #2
jimp's CarPC Specs
My Photos: (2)
I went back through this and started over, got the same results, so I changed the variables priorities to high leaving the temp priorities set to low. this time it all worked, so I stepped the high priorities down to medium, it still worked so I then stepped the Low priorities to medium(now all 4 logics are set at medium) it still is working, next set all 4 back to low, and it is still working!
All I can say is it is working now, why it didn't from the start baffles me but oh well.
Old 04-27-2008, 01:27 PM   #3
jimp's CarPC Specs
My Photos: (2)
Ok so now how do I make a variable increment with time instead of button presses?
Sponsored Links
vB code is On
Trackbacks are Off
HD Radio Mod: Power Antenna Trigger Iceman_jkh Road Runner 38 07-30-2008 12:06 PM
PAC TR-7 Trigger Module archimense General Hardware Discussion 5 04-07-2008 05:02 PM
*NEW* USB 16 Isolated High Current Digital Outputs, IOPoint-USB bibaja_llc Hardware Development 9 07-04-2007 09:47 PM
Trigger wire from Sony Amp..to Where? palmharbor Power Supplies 4 11-24-2006 01:43 PM
In-car PC controlling 12v outputs hardware/software ?!? skinhead General MP3Car Discussion 3 07-18-2006 12:26 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
