Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 12-12-2001, 01:06 AM   #1
Fusion Brain Creator
2k1Toaster's Avatar
Take some pics of the final thing for everyone.
Old 05-18-2008, 10:24 PM   #2
tigergibb's Avatar
Does it run/w carputer off
When programmed, does the FusionBrain store its info when the carputer is off, or does it require the carputer to function? What I'm asking, is can I have the fusion brain do things like turn a courtesy light on/off with the carputer starting or shuting down.
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 05-18-2008, 11:37 PM   #3
2k1Toaster's Avatar
It is computer dependant
Old 05-19-2008, 06:01 PM   #4
The Fusion Brain cannot change output status, without receiving the command from the computer.
What you could do, is pick up a couple of relays from radio shack, and wire one from the USB power of the computer, so it closes the circuit to the courtesy lights when the computer is on, then add a secondary Normally Closed relay, that the FB software automatically shuts off when it starts up.
That should turn on the courtesy lights while the computer boots; but the usb power source might be an issue, as all computers vary, some ALWAYS have usb power, some have power in standby, some only have power when windows is fully loaded... fortunately, the system that I'm using, gives usb power the second you hit the power button, and it shuts off in standby, hibernate, and when the system is shut off.
As long as you have a "trigger" of when to turn something on, and when to turn it off, the possibilities are endless.
peace
Mike
conjur is offline   Reply With Quote
Old 05-19-2008, 09:13 PM   #5
tigergibb's Avatar
well the whole point was that i wanted it to be independent of the computer. in other words, i wanted to get in and lights stay on for 5 secs after i close the door. when i turn off the vehicle, the lights come on for 30 secs. i guess i'll have to use some sort of pic or something for that.
Old 05-19-2008, 10:36 PM   #6
If all you're looking for is a time delayed light, you might want to look into a 555 timer. You can adjust the time by the size of cap and resistor you use.
mx270a is offline   Reply With Quote
Old 05-20-2008, 12:52 AM   #7
2k1Toaster's Avatar
Also I think there are even alarm systems/remote door lock that do just that if you arent familiar with soldering.
Old 05-20-2008, 06:54 PM   #8
tigergibb's Avatar
For this application, I did a little research on the 555 timer and it looks like an excellent idea. Here's how I want it:
When door open wire goes dead, lights come on for 5 seconds.
When IGN wire goes dead, lights come on for 15 seconds.
This will be accomplished with two 555 timers, each shorting 12V to the dome front dome light.
I don't have time to do this right now as I'm working 7 days a week, but hopefully I will have time some day :P
Old 05-21-2008, 09:56 AM   #9
tigergibb's Avatar
Sure will
It will be a little while though as I mentioned earlier because I'm working a lot, not to mention I have a lot of other projects and CarPC parts to finish first(e.g. waterproofing my webcam for a rearview cam, adding another input device, speeding up bootup time, replacing ipod with hard drive).
My 2006 Scion xB (portable) Carputer setup! w/pics! breaker021 Show off your project 26 01-05-2007 09:34 AM
Carputer confusion- n00b needing help TonyMartin Newbie 11 03-10-2006 12:11 PM
Carputer confusion- n00b needing help TonyMartin General Hardware Discussion 2 03-08-2006 09:43 PM
wikipedia: carputer definition pRoFiT Off Topic 2 12-31-2005 08:32 AM
Good time to buy carputer components? Linus General MP3Car Discussion 19 11-25-2004 08:57 PM
