Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 12-02-2008, 08:14 PM   #1
sk8rjess's Avatar
sk8rjess is an unknown quantity at this point
EXTREMELY noob question
actually 2 of them.
first, is is it possible to have FB use buttons? not steering wheel buttons or what not but just a plain button and when its pressed, notify the computer. if so how?
and the next one..
same thing with LEDs. is there a way for the FB to tell the compy when an external led had been turned on, maybe like a radar detector for ex?
its not a fad, nor a trend. its a choice you make for the rest of your life. not just on weekdays or when your alone away from your friends, or even when your with your friends. its a 24/7 true till death commitment.
XXX
sk8rjess is offline   Reply With Quote
Old 12-02-2008, 08:51 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Quote: Originally Posted by sk8rjess View Post
actually 2 of them.
and the next one..
FB can read in anything with a voltage. So yes on the button and yes on the LED.
Old 12-02-2008, 08:53 PM   #3
sk8rjess's Avatar
hmm and how would i go about setting one of those up? would they be in the analog or digital?
XXX
Old 12-02-2008, 09:14 PM   #4
greenman100 is on a distinguished road
Use a light sensor for the LED detection, and analog or digital ins for the buttons.
greenman100 is offline   Reply With Quote
Old 12-02-2008, 09:15 PM   #5
2k1Toaster's Avatar
digital = 1 or 0/ true or fase/5v or 0v
analogue = anything so anything between 5v and 0v
So all digital inputs can be used in an analogue input since both 5v and 0v are in the range of 0v to 5v.
But analogue inputs cannot be used as digital since 3.14v is not 0v or 5v.
So your led is either on or off. That means it can be used on digital.
**EDIT** This is asuming you are soldering directly to the LED pads. If you cant solder or dont want to open it up, then use a light sensor.
A button is pushed or not pushed, which means on or off, so can be used with digital too.
So since they can both be used with digital inputs, they can both be used on analogue inputs.
Our new Fusion Brain will not use any digital inputs since they are so limiting.
Old 12-02-2008, 09:19 PM   #6
sk8rjess's Avatar
so as far as the led goes, i cant actually like splice the LED and then hook it into the board?
XXX
Old 12-02-2008, 11:21 PM   #7
You could solder to the LED and run wires from the LED to the Brain, or you could just use a light sensor.
Old 12-02-2008, 11:23 PM   #8
sk8rjess's Avatar
lol sorry, im just throwing ideas out.
XXX
Old 12-02-2008, 11:23 PM   #9
don't be sorry, I'm just not sure what you mean by "splice the LED"
Old 12-02-2008, 11:56 PM   #10
sk8rjess's Avatar
ah my bad. just instead of actually having to use a sensor to detect when the led is on, could you just somehow splice the + and - of the led into the FB? lol i did a quick paint drawing
XXX
Old 12-03-2008, 12:28 AM   #11
bemenaker's Avatar
bemenaker is on a distinguished road
You should have a resistor in line with your LED or your burn them out faster. They don't have to be big, but it will increase the life greatly.
bemenaker is offline   Reply With Quote
Old 12-03-2008, 12:30 AM   #12
2k1Toaster's Avatar
this is an led on something already, there is already a current limiting resistor.
Old 12-03-2008, 12:54 AM   #13
yup, that'd work fine. + goes to the outer pin on the input, - goes to the middle
Old 12-03-2008, 09:47 AM   #14
sk8rjess's Avatar
i knew about the resistor, but it was just a draw-out to give a better idea of what i was wanting.
sweet! would it be on the digital input?
XXX
Old 12-03-2008, 09:51 AM   #15
2k1Toaster's Avatar
I already gave you the answer... What do you think?
NooB Question: Orion amp paired w/ L7's gab5 Car Audio 12 02-03-2007 06:22 AM
Noob question (capacitor and sub box) greatkiller Car Audio 16 11-13-2006 12:22 AM
Real Noob harddrive question matabra Newbie 1 07-27-2006 07:08 PM
noob question about wiring VW_Carputer Newbie 5 05-24-2006 09:33 PM
Dumb noob question TaZMaNiaK FrodoPlayer 9 04-02-2005 01:52 AM
