Hey all, Started building a CarPC to go into my (UK) Ford Fiesta (1997 model - MK4)
Having to fabricate a way to get my 7" lilliput to fit and thought it would be easier/a good idea to use the PC and FB to control my heaters (no A/C).
I will list my thoughts so far at the bottom
Having taken a look at the switches this is how I have found the heaters are controlled...
The fan speed is controlled by a 4 position switch (0-4) so that, in theory is easy to replicate...
The heater control is a variable resistor. But I havent had a look as to how many wires come from it.
The 'blowing position' (where the fans blow comes out, [demistor, into face, onto feet]) is analogue, cable controlled, a dial is rotated that in turn rotates another cable that closes and opens the vents...
If it makes any difference I am using RoadRunner as my front end...
I Presume the fan speed could just be switched by having three powered outputs from the FB. - I need to check, but I believe only one is active at a time, so would need to make a way for the brain to send out only one (I want to try and replicate the original dial on the screen - or maybe a +/- button if thats easier..
The heater control, again I presume i would just need to replicate the variable resistor, can the FB do this with one output (is that what the analogue outputs are for? or are there only analogue inputs [I cant remember])
I have no idea for the blower position.
Any help would be greatly appreiciated!!
