Quote: Originally Posted by
RonS
Ok I have myself confused. I want to set the FB to control my heater blower. So I need to have 3 outputs. I need Low, Med, and High. When I switch to Low I need to have the FB make sure the other two outputs are not on. And the same with Med and High. How do I make the FB look at the other outputs and make them low. Or just automatically have the other 2 go low when one of them is high.
In the Configurator in the logic section when you put a digital output in the logic, that is a true/false depending on if the output is on or off.
So that is what you use.
