Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 01-15-2009, 06:56 PM   #1
Fusion Brain Creator
greenman100 is on a distinguished road
Yaw Rate/Gyro Board?
Some of you have expressed interest in a gyro/yaw rate board.
If we could find 10 people willing to buy, we'll send a board based on the LISY300AL out for manufacturing.
http://www.st.com/stonline/products/.../lisy300al.pdf
It'd be about $25. Post here if you'd want one.
greenman100 is offline   Reply With Quote
Old 01-15-2009, 09:54 PM   #2
mx270a's Avatar
mx270a is on a distinguished road
I've been using a 75 deg/sec yaw sensor because I need the sensitivity. The guys that have inverted pendulum robots usually use one gyro and two accelerometers to determine the angle. The gyro provides quick reactions, and the accelerometers calibrate where vertical is, and eliminate the drift and bias that a gyro has. They get coupled with a Kalman filter. You might want to look into building a board with a single or dual axis gyro and a 2 or 3 axis accelerometer all on one board. Just an idea.
mx270a is offline   Reply With Quote
Old 02-22-2009, 06:04 PM   #3
ouellettesr is an unknown quantity at this point
I want one.
ouellettesr is offline   Reply With Quote
Old 03-01-2009, 01:11 AM   #4
Glendaflys is an unknown quantity at this point
I want one also.
Glendaflys is offline   Reply With Quote
Old 03-09-2009, 12:31 AM   #5
Flyingboat's Avatar
Flyingboat is an unknown quantity at this point
Sold.
Flyingboat is offline   Reply With Quote
USB Controlled Relay Board or general output 2k1Toaster Hardware Development 68 05-29-2007 12:40 PM
Lilliput Button Board IR Extension FLESIK LCD/Display 0 02-13-2007 03:58 AM
PC Board Etch on Plexi Sillydipstixs18 General Hardware Discussion 10 09-21-2005 07:12 PM
just bought carputer from board member...have a few Q's Tim97rs Newbie 4 05-04-2005 12:24 PM
