Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 01-26-2009, 01:27 PM   #1
customaudioman's Avatar
customaudioman is on a distinguished road
steering wheels control for chrysler
Hey guys, I just sold my 03 accord coupe last friday and bought a 300c. I would like to use the fusion brain in this car also. Does anyone know if the steering wheels control is a one wire or two?
customaudioman is offline   Reply With Quote
Old 01-30-2009, 11:27 AM   #2
anone know where I can find the wire diagram for chrysler 2005 300c?
Old 01-30-2009, 11:55 AM   #3
Laminar's Avatar
Laminar is an unknown quantity at this point
You could try here for starters:
The12Volt
Laminar is offline   Reply With Quote
Old 01-30-2009, 12:48 PM   #4
stealinfool's Avatar
stealinfool is on a distinguished road
I found the installation instructions for a PAC-SWI for your car. This should highlight which wire to use from the factory harness.
http://pac-audio.com/instructions/sw...pp%20guide.pdf
Here's the pinout for your car.
Thank Google.
DON'T PANIC.
Previous install pics in 2k3 S10
Project CarPc V2
stealinfool is offline   Reply With Quote
Old 01-30-2009, 01:04 PM   #5
reromero is an unknown quantity at this point
300c steering controls
here's what i found, note that steering wheel buttons are on a LIN bus to the steering control module. what do you intend to do using these buttons?
reromero is offline   Reply With Quote
Old 01-30-2009, 01:07 PM   #6
which wire color is it on the back of the oem radio that the steering wheel uses to controls the radio?
Old 01-30-2009, 01:12 PM   #7
I want to use the buttons just like I did in my honda accord for my carputer software streetdeck. So I can control the volume up and down, and next song and voice control. Thats why I need the wire color of which wire it is. On my accord it was one wire resistive. The wire was under 5volts which was easy to program with the fusion brain. Just need to know if the chrysler is one or two wires, and if the wire is already under the 5volts to work with the fusion brain.
Old 01-30-2009, 01:13 PM   #8
I need a bigger picture of this diagram or link?
Old 01-30-2009, 01:45 PM   #9
The pinout I gave you is for one of the radio plugs. Find the plug that looks like that. Those two wires are needed, so that probably means that it's a two wire setup. You'll have to correspond those two pins to whatever color the wire may be. You'll also have to use your multimeter and go through the same steps (in the FB tutorial) you did with the Honda.
DON'T PANIC.
Project CarPc V2
Old 01-30-2009, 02:57 PM   #10
Fusion Brain Creator
greenman100 is on a distinguished road
can't use the CAN-bus with the FB
greenman100 is offline   Reply With Quote
Old 01-30-2009, 03:48 PM   #11
so none of the chrysler car you can use the FB becuase it uses can-bus? Most all car use some kind of system like that. gmc, MBenz,bmw ect..
Old 01-30-2009, 06:18 PM   #12
Correct, if you tap into the CAN-Bus, you may cause unwanted results with the many onboard computers in your car.
It can potentially cause a no start condition.
Old 01-30-2009, 11:46 PM   #13
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
You may be able to get to the actual circuit behind the buttons and disable the CAN part altogether. Chop the circuit and wire the buttons straight to the output via the same resistor pattern in the honda.
But just like reromero said, tinkering with the CAN system at all can immobilize the entire car and/or cause permanent damage.
Should have just not given up the honda
Old 01-31-2009, 06:11 AM   #14
Okay guys thanks for all your help. I guess I wont be using the fusion brain for this car. The honda I had cant compare to the car I have now. I never thought I would buy american and be happy with it. thanks for all your help.
Old 02-07-2009, 02:41 AM   #15
ronjon228's Avatar
ronjon228 is on a distinguished road
I have yet to test this, but I have a theory.
If you get the SWI-CAN adapter from PAC, you should be able to tap into your can-bus +/- wires and run those to the SWI-CAN. Then the SWI-CAN should output a usable signal that you can interface with the Fusion Brain. If you already have the FB then the PAC adapter is the only other thing you need to purchase. I haven't tried it yet because I don't want to fork over the dough for the FB and the PAC adapter just for steering wheel controls on my VW.
Any thoughts?
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
ronjon228 is offline   Reply With Quote
VZ Monaro ('04-'05 Pontiac GTO?) Steering Wheel Control interface BradJ Input Devices 3 05-06-2008 09:25 AM
Steering wheel control and durability bimmerpc General Hardware Discussion 4 11-01-2005 03:01 PM
Acura steering wheel volume control implementation jayearl Input Devices 10 09-16-2005 04:30 PM
Wireless control for steering wheel DodgeCummins General MP3Car Discussion 1 02-15-2002 02:14 PM
