Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 02-18-2009, 05:16 PM   #1
GadgetBandit's Avatar
GadgetBandit is an unknown quantity at this point
I need help!
I need to fire a relay for ~1 min. ~ every 20 min.
I'm assumming one function would increment a variable. Another function would fire the relay(with another incrementing variable) and reset the variable. I don't know. Would someone please help?
GabgetBandit.
GadgetBandit is offline   Reply With Quote
Old 02-18-2009, 05:32 PM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
yup.
What are your 4 timers set at?
greenman100 is offline   Reply With Quote
Old 02-18-2009, 05:46 PM   #3
bratnetwork's Avatar
bratnetwork is an unknown quantity at this point
Set your logic timer for 100 so that way your logic will run 10 times every second
If you want to trigger this sequence from a button make a button that will set set a variable to 600.
Code:
<button id="OneMinuteEnable" enabled="yes" function="change variable" functionTargetID="OneMinuteVariable" vote_opinion="600" vote_priority="High"> <images imagePrimary="content\images\button_images\button_down.png" imageSecondary="content\images\button_images\button.png" imageDisabled="content\images\button_images\button.png" imagePushed="content\images\button_images\button_down.png"></images> <display size="230,70" location="287,75" page="0" z_order="0.9"></display> <vote_options minimum_delta_vote_time_down="20"></vote_options> <text font="verdana" font_size="25"></text> <text colourPrimaryARGB="255,255,255,255" textPrimary="Windows Down"></text> <text colourSecondaryARGB="255,255,255,255" textSecondary="Windows Down"></text> </button>
Then in your logic code it to something like this:
Code:
<if fire_on="logic" minimum_delta_vote_time="100" id="one_minute_logic"> <boolean_operation type="greater than"> <parameter1> <variable do="get" name="OneMinuteVariable"></variable> </parameter1> <parameter2> <number>0</number> </parameter2> </boolean_operation> <then> <do function="Trigger Output" functionTargetID="Digital Output 5" vote_opinion="On" vote_priority="Medium"></do> <do function="Change Variable" functionTargetID="OneMinuteVariable" vote_opinion="d-1" vote_priority="Medium"></do> </then> </if>
That will trigger the output on for 1 minute but then you need a logic like this to turn it off:
Code:
<if fire_on="logic" minimum_delta_vote_time="100" id="one_minute_stop_logic"> <boolean_operation type="equal to"> <parameter1> <variable do="get" name="OneMinuteVariable"></variable> </parameter1> <parameter2> <number>0</number> </parameter2> </boolean_operation> <then> <do function="Trigger Output" functionTargetID="Digital Output 5" vote_opinion="Off" vote_priority="low"></do> </then> </if>
Now you would add to that the logic for the 20 minute rest using the same concept as above then after the 20 minuted it would set the variable back to 600 starting the whole process over again...
Hope this gets you on the right track and hopefully my logics work properly... i used them once before and they worked but i modified them a bit to fit what you wanted,
bratnetwork is offline   Reply With Quote
Old 02-18-2009, 11:38 PM   #4
What an excellent example!! Worked great. By the time I got done with my part . . . it didn't work, but I'm close. I didn't realize when I asked today, but the samples you put up, moved my greenhouse to the next level. If the MDX can count to 864000, I've got DAILY cycles!!! Thank you.
GadgetBandit
