Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 03-08-2009, 08:47 PM   #1
Flyingboat's Avatar
Flyingboat is an unknown quantity at this point
GPS based suspension adjustment
Has anyone looked into this?
I've got adjustable dampers that could be easily fitted with some type of stepper motor for adjustment using a Fusion Brain. I should be able to figure that one out on my own.
The question is, how hard would this be to adjust based on GPS position?
I know there is a Roadrunner plugin that may be able to be modified for this (GPS position trigger by Thunderstick).
I'll post up in that thread as well.
I just think this would be a nice enhancement to the heap.
Flyingboat is offline   Reply With Quote
Old 03-08-2009, 09:03 PM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
I don't think GPS is accurate enough to allow you to have individual pot holes in the road as POI's.
Enforcer is offline   Reply With Quote
Old 03-08-2009, 09:54 PM   #3
wi77iam's Avatar
wi77iam
Accelerometers would be better than GPS, since they could react faster. For instance, they could sense a turn and cause your steppers to stiffen the suspension on the side opposite.
The GPS could however provide speed data to fine tune the stepper response, i.e. at faster speeds you would want a stiffer setting than at slower speed.
I've been considering this same idea for a while. I plan to use Phidgets - there are stepper motor controllers and accelerometers, with an API for interfacing with the PC. The only thing I need now is the adjustable struts.
wi77iam is offline   Reply With Quote
Old 03-08-2009, 10:56 PM   #4
Flyingboat's Avatar
Damn. If I drove something European or Japanese I may be worried about potholes. Luckily I purchased an Australian car. lol
I doubt the accelerometers would would help me either. I'm not worried about speed of adjustment.
I was thinking more along the lines of waypoints to trigger settings.
As much as I'd like to have a ZR1 with the magneto rheological supension goodies, I'm stuck here in reality.
Old 03-09-2009, 06:15 AM   #5
rodweb is an unknown quantity at this point
If you are looking at adjustable Struts/shocks, have a look at the Rancho RS9000 which has an in cab wireles controller option to select from 9 different settings. More for 4WD use, but it might get you going. It uses a compressor plumbed to the shock. I have a set of compatible Tough Dog adjustable shocks but am afraid that the in cab adjustment is a long way down the list for me.
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Cool New WinCE based GPS program Rafster GPS 1 01-23-2008 11:46 PM
Blusens Google Imagery based GPS navigator Zoltan GPS 0 10-08-2007 12:56 PM
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 03:59 AM
Garmin announces Mac GPS support for everything! skizot MacCar 11 01-31-2006 04:37 AM
