Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 04-11-2009, 11:03 PM   #1
jabz is an unknown quantity at this point
HVAC help with Fusion Brian
Hi I was looking at another board here for the sole purpose of HVAC control it had software etc but the guy seems to have disappeared.
So I stumbled upon the Fusionbrain, I currently have a CarPC the Infill T3 running the latest Streetdeck V2.
The problem I face is the Infill T3 retractable screen covers up my Climate controls in my Subaru Legacy when it is on. So I would like to get the Fusionbrain and integrate my climate controls with it on the CarPC so I can still use them.
I am however confused as to what to get. My 1999 Legacy has the following climate controls, this is a pic before I installed the Infill T3 CarPC
Do I need anything further than just the FusionBrain? I have opened up the radio area of the dash a few times, and the climate control connectors are easy to reach, however how would I know what wire does what?
And also once hooked up to the Fusionbrain am I still able to use the manual controls on the panel?
jabz is offline   Reply With Quote
Old 04-12-2009, 03:19 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
To figure out what wire does what, you need to find a wiring guide for your car. Depending on how they set it up, you will need various other things. You will need relays at a minimum. Every car is different, there is no DIY guide.
All depends on how you wire it.
Old 04-12-2009, 09:24 PM   #3
Thanks, Also would I need to do any programming, i.e. create a program? I don't know how to program and would rather not. The board that I linked to in original post comes ready to go with software i think, I would like something similar.
Old 04-12-2009, 09:36 PM   #4
csfile's Avatar
csfile is on a distinguished road
you will have to create your own program and graphical interface
csfile is offline   Reply With Quote
Old 04-13-2009, 03:39 AM   #5
2k1Toaster's Avatar
Not true
We provide the software free of charge. You will need to do some configuration since it is a custom setup. But the backbone is all done. We also supply generic images to use in a graphic interface. If you want something unique or something that blends in with your frontend skin or something, then you will need to create those graphics.
Old 04-13-2009, 05:00 AM   #6
rodweb is an unknown quantity at this point
I'm not sure of the capabilities of the Fusion Brain to control HVAC. That is why there is a dedicated controller board out there. To get down to temperature and maintain it really requires more than just turning on and off the air con based on a temp sensor. This requires an Integrative approach so that the temperature is converged on by making big steps if a long way a way and then smaller steps as you get closer to the target temperature. Controllers that do this are called PID's. See here:
http://en.wikipedia.org/wiki/PID_controller
So does the FusionBrain do PID control?
Here is a discussion of a DIY PID approach
http://www.arduino.cc/cgi-bin/yabb2/...m=1226431507/0
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Old 04-13-2009, 05:48 PM   #7
2k1Toaster's Avatar
The software handles all the logic. Anything is possible with the Fusion Brain.
Old 04-13-2009, 06:29 PM   #8
csfile's Avatar
Quote: Originally Posted by 2k1Toaster View Post
Not true
Yes, there is free software (which I must say is pretty good) and it has generic images for a graphical interface. But won't you have to create all the logic? Although I don't think it's very hard after looking at a few examples. And there's plenty of support on these forums.
Old 04-13-2009, 06:35 PM   #9
Dan2008 is an unknown quantity at this point
Yes, you have to create the steps (logic) but it isn't that difficult. The biggest challenge will probably be in creating the interface (hardware) between the Fusion Brain and your AC unit.
Thanks,
Dan
Dan2008 is offline   Reply With Quote
Old 05-14-2009, 08:55 AM   #10
JoeyFiasco is an unknown quantity at this point
too bad that dude disappeared that looked promising.
JoeyFiasco is offline   Reply With Quote
Old 07-14-2009, 06:34 AM   #11
time to re-visit this..
I don't want fusion brain to take over and maintain the HVAC, that may come later. All I want is it to push the buttons to turn it on, change options (buttons), adjust temperature, turn on/off A/C or just the heater while letting the car itself control the HVAC
So basically just activate buttons or turn the temp dial through signals to the correct wires. Since the physical buttons aren't reachable when my CarPC screen is up.
Is this possible and simple to setup without programming? Can the existing software do it just requires some configuration?
thanks
Old 07-14-2009, 03:44 PM   #12
2k1Toaster's Avatar
thanks
Yup.
Fusion Brain and Auto HVAC. h3rk where are you? Willn Fusion Brain 4 04-17-2009 10:08 AM
eyeR MOD for the Fusion Brain, add PWM, Servo and remote control. (eyeR Interceptor) Civic Modz Fusion Brain Innovations 17 01-16-2009 10:48 AM
September 9, 2008 - The Fusion Brain – How do you use it in your car? Heather Mp3Car Blog Talk 3 09-23-2008 10:00 PM
How to add a Fusion Brain instance to your configuration file 2k1Toaster FB Documentation and Tutorials 0 06-07-2008 09:42 AM
