Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 05-01-2009, 06:02 PM   #1
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
FB powered valet switch... is this right?
I'm looking to make a "valet" switch of sorts using my fusion brain. basically i want to have a relay hooked into the accessory line on my m2-atx. When powered the relay will keep the line hot so that my computer doesnt turn off even though the key is out of the ignition. Sound like it would work? Does the FB provide enough power to keep acc hot? If there's something i'm not thinking of by all means let me know lol.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 05-01-2009, 08:03 PM   #2
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
That's not technically a valet switch, but yes it would work with the proper protection. Problem is though, there are multiple ACC lines on a car, all connected to the original starter. It's hard to explain but you'd have to power them all to keep the ACC line hot.
If you JUST wanted your computer hot, you could just send +12v to the ACC line of the PSU you're using. Except be careful in case you forget to shut it off. Make sure you add some sort of 555 timer that starts when the ACC goes off.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 05-01-2009, 09:06 PM   #3
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
Why not save the FB resources for other stuff and do this with this.
Actually, my new switch does the same thing but is illuminated whenever power is on so when I get out I know with a glance if its set to On/Off/Auto.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is online now   Reply With Quote
Old 05-02-2009, 03:01 PM   #4
Terminal flasher
pretty much cause i have the FB and its not really doing anything for me a the moment lol. Trying to get something outta the $$$ investment... not to mention the time invested in RRFusion.
03 Acura RSX Coupe
Wiring a master switch, help! Kalenth Power Supplies 8 02-07-2009 04:02 PM
Use Fb as 3 position switch? Dougw133 Fusion Brain 3 11-18-2008 10:36 PM
Simple and clean DC to AC inverter remote switch on mod WarDriver Power Supplies 10 09-21-2008 06:26 PM
Help needed on switch install for Inverter eazyrog Power Supplies 9 07-24-2004 07:42 AM
Savage Switch Botton Group Buy via UK's Iconstyling.com.... TheBigDog General Hardware Discussion 3 07-21-2004 11:51 AM
