Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 05-20-2009, 02:34 PM   #1
jctman is an unknown quantity at this point
Fluid Level Sensor hookup
I bought this nice fluid level sensor that is powered by 12vdc and outputs 0 to 5 vdc. 0 being empty, 5 being full. So my issue is, I have 2 leads(+,-) from the 0 to 5 vdc source and 3 leads(+,-,an) on the analog input of the FB. To connect a voltage source to the analog input, which leads are used and how?
jctman is offline   Reply With Quote
Old 05-20-2009, 02:55 PM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Moved to FB main forum and the Tutorial and Documentation forum is for?
Yes you guessed it Tutorials or documentation.
Enforcer is online now   Reply With Quote
Old 05-20-2009, 05:16 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Then AIN is the analogue input. That is what does the reading.
Ground is ground.
so your sensors + output goes to AIN. Your sensors ground output goes to -
Old 06-16-2009, 01:52 PM   #4
monty9991 is an unknown quantity at this point
did the fliud sensor worked for you?
monty9991 is offline   Reply With Quote
Old 06-30-2009, 03:13 PM   #5
GadgetBandit's Avatar
GadgetBandit is an unknown quantity at this point
I'm also interested to know how this worked out.
GadgetBandit
GadgetBandit is offline   Reply With Quote
Old 07-17-2009, 09:09 PM   #6
djurchicprelude is on a distinguished road
any updates on this?
djurchicprelude is offline   Reply With Quote
n00bular question about output level kevin1162 Car Audio 6 03-04-2009 08:01 AM
Annoying problem with Sound Level (SD automatically adjusts level to mid) Nola111 StreetDeck 2 07-30-2007 08:31 PM
Headphone vs line level outputs from computer, etc. timeshifter Car Audio 3 12-31-2006 01:21 PM
high level inputs and low level inputs, what does it mean? TiTUS General Hardware Discussion 4 09-28-2003 10:51 PM
