Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 06-07-2009, 12:23 PM   #1
wilgartw is an unknown quantity at this point
where to start
I bought my FB a couple of years ago and struggled. I have now come back to it and everything has changed.
I have a carputer, and want to control winamp through buttonson my dash (volume, play, stop, rwd, ffwd(
I have read through the tutorials but have a few questions first.
1. Can i develop on my vista machine even though my carputer will is XP?
2. do i still need to develop a skin, even though i don't need to see the output?
3. can the volume control control master volume now (rather than winamp volume?)
wilgartw is offline   Reply With Quote
Old 06-07-2009, 05:30 PM   #2
Iamthehor is on a distinguished road
1 Should be no problem. I have a VB program I wrote on XP & works/edits fine in vista 64, can't use MDX on 64bit though. Next test is win7 32bit (quick trial did some wierd things, not sure if it was a problem or just something else goin on)
2 nope, just make the logic do it all
3. not sure, it's going to depend on how you are interacting from MDX->Winamp/windows (not sure if MDX can do that yet, VB could)
Iamthehor is offline   Reply With Quote
Old 06-07-2009, 06:30 PM   #3
also, when using the mdx i get told there are no fusion brains connected, does it not support the earlier versions of the brain?
Old 06-07-2009, 07:09 PM   #4
csfile's Avatar
csfile is on a distinguished road
which version do you have? works fine for both my version 3 and version 4
csfile is offline   Reply With Quote
Old 06-08-2009, 06:57 AM   #5
Dan2008 is an unknown quantity at this point
Make sure you specify brain version 3 in the config file.
Thanks,
Dan
Dan2008 is offline   Reply With Quote
Old 06-08-2009, 08:43 AM   #6
i am not sure which version i have, i bought it in Jun/Jul 2007
here is a pic.
Old 06-08-2009, 12:49 PM   #7
that's a v3. You need to open the .xml and change the version.
Old 06-08-2009, 01:47 PM   #8
thanks, but i do not think i have got that far yet.
my brain is powered, and linked to usb.
i open "MDX configurator"
and click on add brain
the "brain form" pops up.
and i click the magnifying glass next to ID.
i then get an error message saying "no version 4 brains were detected" and "no version 3 brains were detected"
fallen at first hurdle?
Old 06-08-2009, 02:02 PM   #9
hold on, no lights on the brain. and a puff of smoke from the 1 of the 2 smaller chips.
i guess that's not good?
Old 06-08-2009, 02:03 PM   #10
actually the chip has a crack in it... guess that's not good either
Old 06-08-2009, 02:40 PM   #11
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
Nah dont worry, lots of chips have cracks in them!
Thats a joke :P Sounds like you blew a driver chip. That typically means one of your outputs is shorted.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 06-08-2009, 03:51 PM   #12
i am not using any outputs
Old 06-08-2009, 08:52 PM   #13
Fusion Brain Creator
greenman100 is on a distinguished road
or you hooked up your power supply backwards. either way, not good.
greenman100 is offline   Reply With Quote
Old 06-09-2009, 04:28 AM   #14
ok, quite certain i haven't unless the power supply in the house has a positive outer, i'll check this tonight.
i've ordered a new brain. it looks like the project is on hold again.
Old 06-17-2009, 04:16 PM   #15
what a numpty,
i tested the power supply with a chepo battery tester, 12v +ve inner, great no probs.
when i tried it again (after blowing the brain, i thought i'd reverse the battery tester, still 12v ... hmmmm ... the power supply was 12v AC!!!!
Remote Start Fried? Car continously tries to start Phatsacks General Hardware Discussion 4 08-17-2008 06:39 PM
when i start my car, no sound nickthegreek General Hardware Discussion 1 04-25-2008 10:18 AM
Failed Hiding of Start Bar, Minimize Errors DaRacerz RR Bug Tracker 4 11-04-2005 05:36 PM
RR doesn't start Phoco on initial load.. DutchBurner Road Runner 16 11-04-2005 02:17 PM
