Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 06-22-2009, 07:33 PM   #1
wilgartw is an unknown quantity at this point
controlling winamp volume
i had this working a couple of years ago, but with a v4 and the mdx i have no idea where to start.
i started the ninja wizard.
said i had one analogue port, and no digital outs.
i have a skin with a single box.
what settings do i need to change to control winamp?
wilgartw is offline   Reply With Quote
Old 06-23-2009, 09:51 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Do you want to control winamp or RoadRunner?
All you have to do to control winamp is add a display button and change its down vote option to send keystroke.
Old 07-03-2009, 07:26 AM   #3
i am using winamp through road runner.
my ideal would be to be able to control the windows (xp) master volume, is this possible?
before i blow up another brain, a couple of quick questions on the wiring.
i now have a v4 brain (previously had v3) looking at it it looks like there is a jumper to run it off 12v dc input, or 5v usb. is this true? is there any documentation on this. is it just a matter of moving the jumper? what are the pros and cons?
analogue inputs.
they seem to be marks up as +,-,AN.
if i want to detect a digital switch do i jusrt connect a swicth between + and AN?
if i want to detect an analogue reading from a potentiometer, do i just connect the potentiomemter to + and AN? ( if i measure the resistance of the potentiomemter i get between 0 and 1)
I have another output on the pot that goes in reverse, 1 to 0 do i just ignore this or does this connect to -?)
thanks.
Old 07-05-2009, 07:09 PM   #4
ok ignore all of the above i have a mdx skin that now displays the "volume" voltage. and also displays the voltage of the digital buttons that i want to ffwd, play, rewind in roadrunner/winamp.
so i guess i need to put in the logic.
can anyone point me in the right direction from here?
Old 07-05-2009, 07:47 PM   #5
hello again!
right i've got it firing a "b" to ffwd winamp when i press my digital button. but it fires too quickly. as i press it it sends 3-4 "b's" so skips 4 tracks.
how do i slow down the repeat rate?
Old 07-05-2009, 08:22 PM   #6
also, it only seems to work when winamp has focus... is this s setting?
edit:
it only seems to work when i have a screen i can type into.
eg if i have the forum open in IE it doesn't work.
if i have this screen "reply to thread" it does....
Old 07-05-2009, 08:37 PM   #7
2k1Toaster's Avatar
Quote: Originally Posted by wilgartw View Post
hello again!
Change the minimum vote time higher. Also turn auto-averaging off so the input doesnt "float" when nothing is pressed.
Old 07-05-2009, 08:38 PM   #8
2k1Toaster's Avatar
edit:
You are probably using "send key to foreground". You need to use send key, and then enter the info for winamp's window frame.
Old 07-06-2009, 11:24 AM   #9
hi thanks for your replies.
i'll have a rummage tonight for the minimum vote time. that sounds like it'll do the trick.
I am quite certain i used the "send key" rather than "send key to foreground" i found some old threads that said that i just needed to put "winamp" into the target ID. i left all the other fields blank, is this correct.
Old 07-06-2009, 11:30 AM   #10
2k1Toaster's Avatar
In the logic section where you draw out the functions, you can select it there. Each logic block can be different as well, so one button can be X seconds, another can be Y seconds, and etc.
That is true for older winamp. At the time, RoadRunner was suggested to use version 2.95, and that is what the program was setup for. If you are using the new version, you may have to use the target icon to select the window. After you choose send key, a little target appears, click that, and then a window pops up. Drag the target icon to winamp's window and it should capture most of the info it needs. I dont use anything but 2.95 in classic skin mode, so I don't know the details on what should popup.
Also I want to thank you for actually using the forums and searching. It really helps out a lot.
Old 07-06-2009, 11:47 AM   #11
yep, i'm using winamp 2.95 (this too was on an old post). I'll have a good play tonight to see what's what.
i'll give the dragging of the target a go. will it matter that i am developing on my home pc, rather than my carputer?
Old 07-06-2009, 11:53 AM   #12
2k1Toaster's Avatar
It shouldnt matter assuming you have the same software.
Old 07-06-2009, 11:57 AM   #13
same software (winamp 2.95, roadrunner etc), but one is on XP, one on vista. i presume this won't be an issue.
Old 07-06-2009, 12:15 PM   #14
2k1Toaster's Avatar
If you are using Vista you have to run it in Administrator mode. (Right click run as admin). Just being an admin on the computer is NOT enough.
Old 07-06-2009, 01:08 PM   #15
hello, at home now.
i am in the logic diagrams, i have a timer (alarm clock item) that sets the dTime. is this the minumum vote time?
Why does my Winamp volume go to zero after I exit then restart RR? mstaedt Road Runner 16 01-03-2009 05:59 AM
Volume leveling DSP plugin for winamp? DeaconC Newbie 0 05-01-2008 01:33 AM
Volume Slider garto Road Runner 0 05-13-2007 01:11 PM
Road Runner Volume Issues ! ! ! rewindnottm Road Runner 8 03-20-2007 04:38 AM
Advanced Title Formatting (ATF) for Winamp ID3 Decoding GizmoQ Road Runner 3 11-23-2006 11:14 AM
