Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 06-24-2009, 07:34 AM   #1
Ryann is on a distinguished road
NES controller into FB
ok so i have an oldskool NES controller i bought and i want to use it as an alternative to the touchscreen for firing some functions in MDX.. i have the very first model.. looks like this..
Now how about i go about wiring this into the FB? as you can see here the wiring setup.. obviously ill need to use more then one port?
hopefully someone can help me, as different keys will output different voltages.. and well, if i can use all the buttons that would be epic..
Ryann
Ryann is offline   Reply With Quote
Old 06-24-2009, 12:27 PM   #2
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
They don't output different voltages. I know because I made myself a NES - USB converter. It is all just a shift register. You clock the chip inside the controller and it outputs the information about which button is pressed.
It's a very simple system and with some clever coding you could probably achieve it easily enough. If not, there's a company called ZeroSoft which gives you a schematic and code to make your own NES - USB converter. You can turn it into a mouse or you can use it as a joystick. I think the newer versions let you do both if you do a special key combination.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 06-24-2009, 12:37 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Ryann
Are you sure about that?
I am fairly certain that the NES controller was a pure digital signal. It latched the button presses to a shift register, then clocked the controller and every button's state was sent back to the NES.
I would say open it up and wire each button (they already have pull up resistors) to an input. That is the easiest way. 1 input = 1 button.
EDIT: Beat to the punch... That's what I get for having so many tabs open at once!
Old 06-24-2009, 12:41 PM   #4
colin's Avatar
Oops
Blog
Code:
Old 06-26-2009, 06:30 AM   #5
definately not sure of that 2k, im basing this off assumption.. haha ill pull it apart over the weekend and have a look.. cheers for the replies
Old 06-26-2009, 02:48 PM   #6
colin's Avatar
Ryan, we're 100% sure it's a shift register.
Blog
Code:
Shutdown controller screwc149 Power Supplies 1 11-22-2006 11:38 AM
Allbrite and controller work with RCA but not VGA alti LCD/Display 22 01-05-2005 01:47 PM
Xenarc VGA Controller Features 1300mer LCD/Display 0 07-05-2004 01:46 PM
FS: M1023 Rev E controller + inverter + 10.4" screen jusatry Classified Archive 2 05-12-2004 03:09 PM
Trade 8.4" LCD with controller for Alan controller Sleeka Classified Archive 3 05-15-2002 12:09 AM
