Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 09-07-2009, 06:48 PM   #1
yonu is on a distinguished road
fuse size
simple question what size fuse should I use to fuse the fusion brainV3 when using it on un regulaqted power?
yonu is offline   Reply With Quote
Old 09-07-2009, 09:51 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
There is a built in thermal fuse. Each relay takes about 500mA so just add them up that way. You really dont need an external fuse.
Old 09-08-2009, 10:16 AM   #3
cool thanks that is what i needed to know I wasn't sure so I gihured it was better to ask
Old 09-15-2009, 06:31 PM   #4
FredWorrell is an unknown quantity at this point
Here is something to consider from the aviation world. First everything has a fuse or circuit breaker. Second, the fuse (or breaker) size is dependent on the wire size. The fuse is to protect the wiring, not the component. This really makes sense, the first time you short out a wire and burn up a wire bundle or start a fire. Absolutely makes no difference what is connected to the wire. Just for your consideration.
FredWorrell is offline   Reply With Quote
Easy powered subwoofer install in a 2005 Saab 9-3... Gruuve Car Audio 2 08-11-2009 07:46 PM
Lost cylinder fuse in my LCD monitor. What amp replacement? PapaPrem LCD/Display 3 08-13-2006 02:13 PM
Size Of ANL Fuse? bird Car Audio 6 05-11-2006 03:15 AM
Opus 120, 12V line from battery, what size fuse? 01black_ac Power Supplies 21 04-12-2006 12:53 AM
low amp fuse blowing in MX radio adaptor march09 Car Audio 1 01-06-2006 06:53 PM
