Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 11-04-2009, 05:40 PM   #1
JiC
JiC is an unknown quantity at this point
Fusion outputs and hibernate/resume
I'm using 1 output to control a relay that powers my amps remote wires.
I have the default of the output to off
I'm using the ExecTBL.ini of RR to send commands:
"ONRESUME","fusion_vote_AmpON"
This command works A-OK, only problem is when coming back from hibernate the fusion brain restores the last state of the output (on) before my PC is ready (and before AmpON gets called) and I get a big screech and thump. It works fine if I manually turn off the output before hibernating.
I try using this command:
"ONSUSPEND","fusion_vote_AmpOFF"
but it throws an error.
Any ideas or input from anyone would be much appreciated!
JiC is offline   Reply With Quote
Old 11-05-2009, 12:08 AM   #2
JiC
I got impatient and just added ign,acc inputs to the fusion brain (3.3k and 10k voltage divider). When they are both 0, I turn the output off.
Works well enough for now. Plus I like having a volt-meter. Should I be worried about voltage spikes or anything like that?
Old 11-05-2009, 04:03 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Not sure why I never got an email about this thread until today, but sorry I missed it.
The divider will work just fine, and like you said, you get the nifty voltmeter too. Spikes would be a worry, as with all non-isolated circuits. If you are handy with electronics, a simple unity gain opamp after the divider, or an optoisolator would be preferred. If you would rather just buy something, then we sell a 4channel isolator with built in divider so you would just hook the +12v inputs direct to it, then direct to the FB.
But you shouldn't have any problems. Yet again, your house shouldn't burn down yet we all have fire extinguishers (I hope ).
Old 11-05-2009, 10:27 PM   #4
JiC
Thanks for the info! I'm a computer engineering student, we haven't used opto-isolators yet but this sounds like a fun way to learn.
Old 11-05-2009, 10:31 PM   #5
2k1Toaster's Avatar
mouser.com has some good products for prototyping at reasonable rates and cheap shipping inside the US.
Just test your circuits with bench supplies and multimeters before you go hooking it up to the Fusion Brain!
Disable hibernate/resume error message? b8bboi WinNT Based 17 03-27-2009 09:17 AM
Xport "forgetting" settings after hibernate/resume? Curiosity GPS 1 05-20-2008 05:08 PM
resuming music playback on hibernate/resume? GreenBeast Mobile Impact 6 08-08-2005 12:14 PM
