Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 04-17-2007, 12:35 PM   #166
Fusion Brain Creator
greenman100 is on a distinguished road
Quote: Originally Posted by P3D4T0R View Post
i was wondering about an update on the ETA of the boards (I really am impatient)... Also with the latest update to StreetDeck Iv had to ditch the program I was building, so I will probably try integrating the program strait into StreetDeck or use the DLL that Fusion Brain will provide... or something in between.
They should be in the mail sometime this week. We caught a few bugs already, and are working them out. Keep in mind this is a full product development from scratch... it takes time. We will post a video of it working later today.
greenman100 is offline   Reply With Quote
Old 04-17-2007, 12:49 PM   #167
P3D4T0R's Avatar
P3D4T0R is an unknown quantity at this point
I know how that goes... I built my own RFID kill switch for my car. I was just wondering how it was going plus I wanted to give an update on my side of things.
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
P3D4T0R is offline   Reply With Quote
Old 04-17-2007, 09:25 PM   #168
Video:
http://fusioncontrolcentre.com/alphatest2.mp4
http://fusioncontrolcentre.com/alphatest2.avi
Current status:
Digital Outputs - all functional and tested
Analog Inputs - all functional and tested
Digital inputs - tested, needs minor change in firmware (<5 minutes) but I am away from my PIC programmer.
so: The beta boards will be shipped this week for SURE. Then, we will have a beta period, likely a week or two.
Old 04-17-2007, 11:26 PM   #169
updated 4th post to reflect the above.
please give Nick and I feedback on how we are doing. we are here to serve you. we can shift around priorities, work on different aspects. about all we can't change is the overall timeline... I know you guys want this immediately, but thousands of lines of code and hundreds of hours of research don't happen instantly.
Old 04-17-2007, 11:38 PM   #170
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
what's the easiest way to play an mp4?
turbocad6 is offline   Reply With Quote
Old 04-17-2007, 11:43 PM   #171
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Use DOS and a binary decompiler to display the raw binary data. Then try to picture what it should look like.
Or use quicktime/wmp/winamp/anything that is free...
Old 04-18-2007, 12:01 AM   #172
turbocad6's Avatar
my wmp & winamp both don't know what to do with it, too lazy right now to start searching for codecs
gotta either try that dos thing or try it tommorow at work
Old 04-18-2007, 12:03 AM   #173
2k1Toaster's Avatar
quicktime perhaps?
I'll renencode it, and repost it just incase
Old 04-18-2007, 12:25 AM   #174
re-uploaded as AVI, LMK if it works
Old 04-18-2007, 12:26 AM   #175
P3D4T0R's Avatar
Nvm
Old 04-18-2007, 01:12 AM   #176
P3D4T0R's Avatar
I know (for me) it probably wouldn't be hard to physically add them but I was wondering if maybe in a future release of the board its self if you could add headers for external LEDs to ether replace or as just an add onto the LEDs already on the board.
Old 04-18-2007, 01:38 AM   #177
Why not just use the output headers already on the board? They supply switched 12vDC.
Old 04-18-2007, 01:54 AM   #178
P3D4T0R's Avatar
That's what I was thinking, but then you'd need to add other things like resistors and the like. What are the on board LEDs rated as? Because If you set the headers to those LEDs then it would save the end user some trouble. Thats the conclusion I came to in the end, K.I.S.S.
Old 04-18-2007, 02:07 AM   #179
True, but then what resistance would you use? It should change with the color of the LED (different breakdown voltages).
It just seems like a header for a very specific use. We're trying to keep the board simple with as few connections as possible. We will think about it though, and see if we can come up with something.
Old 04-18-2007, 02:10 AM   #180
P3D4T0R's Avatar
It was just a thought for a feature... most LEDs run on 3.3v to 5v so running 12v to them is a pretty bad idea, I know of some LEDs that can run off of 12v but the are rare and expensive so I figured id throw the idea out there to see what you thought
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 21 02-06-2009 11:33 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 03:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
