04-22-2007, 12:38 AM
#241
Super Moderator. If my typing sucks it's probably because I'm driving....
tough call there, if I had to choose I think I'd go with the 4-30, theres nothing more annoying than being at full alert warning with 8 inches to spare, the closer distances are what these things are best help at, would be nice if there were higher resolution units...
#242
Fusion Brain Creator
Quote: Originally Posted by P3D4T0R
Liquid Temperature Sensors... for engine coolant or other liquid things...
our temp sensors will work fine for this, just dip them in epoxy
04-22-2007, 12:42 AM
#243
Alright... What is the operating temp to the sensors? I cant remember if it was mentioned before and I'm to tired to look
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
04-22-2007, 12:47 AM
#244
They are rated for 10 C to + 125 C, which is 14 to 257 F.
I have personally tested them to 225C, which is about 425F. I do not guarantee them past 125C, but I have seen them work much higher.
04-22-2007, 12:50 AM
#245
Awesome, I think most car coolant systems in cars (at least in my car and my buddies car) hover around 200F-210F
04-22-2007, 01:04 AM
#246
certain sensors are going to be better to source yourself too, for example a factory style screw in temp sensor may be easier to do reliably, & pressure sensors are similar, in that there are just so many different possible configurations that a sensor like that could be used in...
04-22-2007, 01:13 AM
#247
Here are some more ideas...
Magnetic Sensor
Vibration Sensor
Motion Sensor
IR Distance Sensor <- more accurate then an audio version
Rotation Sensor <- I.E. Volume control
Multi-turn Rotation Sensor
04-22-2007, 01:16 AM
#248
I was thinking something like this could be used for tire/gas/oil/coolant/whatever pressure: http://www.phidgets.com/index.php?mo...144.227&IID=82
04-22-2007, 01:18 AM
#249
Magnetic Sensor
Vibration Sensor
Motion Sensor
Magnetic sensor is a possibility, but for what? I don't wan to order a bunch and then no one buys them.
Accelerometer can handle vibration
Motion is a good possiblity.
IR is covered above, that's what I planned on using.
1 turn/infinite turn rotation sensors are in the works, I have emails in to several companies.
04-22-2007, 01:19 AM
#250
This can also be done, would be about $20.
The big thing here is interest. A lot of these sensors are only available in quantities of like 100, and I don't want to buy a bunch if no one wants them.
04-22-2007, 01:28 AM
#251
I don't know what a magnetic sensor would be used for I'm just trying to through out possible ideas... as for the pressure sensor I could use one for each tire plus my coolant, my oil, gas, NOS, Boost, and whatever else I may want to measure pressure on in my car. I know most people wouldn't want to go to this kind of extreme, I probably wont because of the cost but it may be safe to say 100 could sell out easily.
04-22-2007, 03:04 AM
#252
i really need to have a pressure sensor that can read air pressure upto like 200psi, is there anything on the marlet to do this? and possible for u guys to implement?
04-22-2007, 03:12 AM
#253
When it comes to something like that you might need to go custom and implement it yourself, this should get you started
http://www.meas-spec.com/myMeas/down...p/MSP-5100.pdf
http://www.omegadyne.com/ppt/prod.html?ref=PX6000-5V
http://www.omega.com/pptst/PX102.html
I may want something like this as well but I know not very many people will want something like this so I'm going my own way with it.
P.S. It wont be cheap
04-22-2007, 03:13 AM
#254
Yes.
http://rocky.digikey.com/WebLib/Meas...a%20Stable.pdf
But you're looking at about $70 a sensor.
04-22-2007, 03:24 AM
#255
Well i know dakota uses these on there systems but i dunno if i could use them along with this. anyone know how these work?, they screw into a airline to get the pressure. and i guess send a resistance back?
http://www.dakotadigital.com/index.c...rod/prd124.htm
| Thread Tools |
| Display Modes |
Linear Mode
