Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 04-23-2007, 04:49 PM   #271
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Who needs a driver.
One sec, I'll find and post/edit this.
Old 04-23-2007, 04:50 PM   #272
P3D4T0R's Avatar
P3D4T0R is an unknown quantity at this point
Quote: Originally Posted by 2k1Toaster View Post
Who needs a driver.
HAHA... Its a feature: Paperweight function
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
P3D4T0R is offline   Reply With Quote
Old 04-23-2007, 04:51 PM   #273
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
got mine too... soldering it up for my initial stuff is trivial, I guess I need software to to do anything with this too
turbocad6 is offline   Reply With Quote
Old 04-23-2007, 04:52 PM   #274
2k1Toaster's Avatar
Here you go: http://www.fusioncontrolcentre.com/S...on_Drivers.zip
Old 04-23-2007, 04:53 PM   #275
2k1Toaster's Avatar
Soldering!
I guess you are the first Fusion hax0r!
Old 04-23-2007, 04:58 PM   #276
turbocad6's Avatar
yeah man, instead of ordering all the headers & connectors & stuff I'll just solder it up, works for me
Old 04-23-2007, 05:30 PM   #277
P3D4T0R's Avatar
I found an interesting error in the board... Im not sure if this is the software of the brain but when I turn on DO#7 DO#8 turns off/will not go on. Two other things, as well. One, the board will disconnect and immediately reconnect to the computer; seems like a driver problem. When this happens if something is on it will turn off if its default is not set. Two, not sure if this is what its supposed to do but when defaults are set on a DO and the USB is disconnected (Simulating the computer being off) and the program is not set to defaults before this the board dose not return to default. <- This is what I meant by the feature request I made a while back.
I forgot to mention that since I do not have my car right now I'm testing it on my home/work system which is running Vista which may explain some of the problems Im having.
Old 04-23-2007, 06:09 PM   #278
greenman100 is on a distinguished road
1. Some boards have bad LEDs. this is a QC issue we will try to work out with the PCB manufactur. Try putting your relay on the output and seeing if it responds. I remember two boards had bad LEDs.
2. The board disconnecting/reconnecting is a particularly annoying issue, one I became aware of after I mailed the boards. Nick and I are working on this. It is hard to solve because it is so intermittent.
3. Nick will respond to the default behavior.
Thanks for working with us guys, there will be issues but we will mail you new PICs with updated firmware as I get them worked out.
greenman100 is offline   Reply With Quote
Old 04-23-2007, 06:14 PM   #279
P3D4T0R's Avatar
1. This is what I thought at first but I tested it and with OD#7 and #8 on through software; #8 will be off (no power with volt meter) but if I turn #7 off, leaving #8 on, #8 will come on. This is repeated while turning #7 on and off.
2. Aleast you know about it :shrug:
3. ...
Old 04-23-2007, 06:17 PM   #280
I really need help on the disconnect/reconnect thing, guys. any bug reports or information you can give me would be appreciated. It is hard to troubleshoot because it is so intermittent. I've had the board go all night without disconnecting, and I've had it do it 3 times in 10 minutes.
Old 04-23-2007, 06:18 PM   #281
3. ...
I really think this is a problem with your board. I can't duplicate it on this end. We will see though, if other people have the same troubles.
Old 04-23-2007, 06:24 PM   #282
P3D4T0R's Avatar
OK, Is their a way for me to check/re-flash the firmware from here?
Old 04-23-2007, 06:41 PM   #283
Eventually, yes. Right now, no, unless you have access to a 40 pin programmer.
Old 04-23-2007, 06:42 PM   #284
2k1Toaster's Avatar
Very weird. I have not had this problem, and as far as I know neither has Tim, so I am fairly certain it is not a software problem. As Tim said, our manufacturer must have been smoking some crack or something when they did a couple boards... I cant tell because I am red green colour blind, but apparently, some leds are green, and some are yellow, and some are red. So god only knows whatelse they f'ed up.
A couple troubleshooting questions:
1.) Does ouput #8 work fine with ouput #7 off?
2.) Do you see any solder bridges between out #7 and out #8 on your board? They were hand-soldered, so there very well might be mistakes unfortuneatly. We will have a harshly worded email with our manufacturer if this is the case.
3.) Does it just not work at all, or does it go on and then off?
The board will disconnect and immediately reconnect to the computer; seems like a driver problem.
Yeah this is a strange problem... What length cable are you using? This seems like a magical "fix" sort of at least on my end. I used a 6' cable and all was well and a 12' and it kept happening. Like Tim said, hard to diagnose. It doesn't seem to make any sense. We checked the physical temperature, and it seemed within the specs. Also the software communicates through the dll, and the dll only transmits if the device is a-ok. So the dll and the software seem to be doing fine. Proof being once it reconnects, no crashes and it starts going right where it left off.
This should not be the case. It should stay in suspended animation sort of. Like whatever was on, stays on, and whatever was off, stays off. Once yours disconnects, do your outputs all go to off?
When the program closes all the outputs go to off. And when the program is restarted, they all go back to default. Soon the program will detect going into standby/hibernate and set to all off. And then upon resume go to defualt.
is this not what you had in mind?
Seems like for once Vista is not the culprit. ... unfortuneatly. But hence the beta period.
Old 04-23-2007, 07:07 PM   #285
P3D4T0R's Avatar
1. Yes, it works fine while #7 is off
2. No, It appears clean to me
3. It will work normally while #7 is off but #7 is almost like a switch when it goes on #8 turns off and will remain that way until #7 turns off again. If #8 is off and #7 turns on #8 will stay off.
I believe it is 6'-8' Long
What I did to test the computer being shut off was simple, I just unplugged the USB cable. When I did this the ones that were on stayed on, the ones with animations stopped animating; passed in whatever state they were in (on/off), the ones that were set to default on but were off then i disconnected the USB stayed off... The idea I had was when there is no connection the the computer but there was power that the DO's would be in there default state.
What I had in mind was a to go into default when there is no communication with the program... however, in writing this I think what you have plus what I had in mind would be nice to chose between in settings.
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 21 02-06-2009 11:33 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 03:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
