The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Thread Tools Display Modes
Old 04-23-2007, 06:17 PM   #286
Fusion Brain Creator
My Photos: (0)
Quote: Originally Posted by P3D4T0R View Post
One, the board will disconnect and immediately reconnect to the computer; seems like a driver problem.
I think I found the problem here. I'm letting it run for a while to check.
also her ei sa picture of the PIC capturing the top half of a sine wave.
greenman100 is online now   Reply With Quote
Sponsored Links
Old 04-23-2007, 06:19 PM   #287
My Photos: (0)
What I did to test the computer being shut off was simple, I just unplugged the USB cable. When I did this the ones that were on stayed on, the ones with animations stopped animating; passed in whatever state they were in (on/off), the ones that were set to default on but were off then i disconnected the USB stayed off... The idea I had was when there is no connection the the computer but there was power that the DO's would be in there default state.
This will happen for now. If you shutdown the computer normally, the fusion software will shut down, and on its way out, will set all the outputs to zero. try it.
Eventually, the PIC will sense USB, too.... but there was less than a week for me to write the firmware
Old 04-23-2007, 06:25 PM   #288
Rowan's CarPC Specs
Rowan's Avatar
Vehicle: 2003 Holden VY Calais LS1
My Photos: (0)
I forgot to mention that since I do not have my car right now I'm testing it on my home/work system which is running Vista which may explain some of the problems Im having.
Vista could be a problem, I remember reading somewhere on the microchip forums that Vista and the CNC firmware didn't like eachother. Unfortunately microchip.com is down for maintenance at the moment, so I can't confirm what I heard..
http://forum.microchip.com/tm.aspx?m=241830
Is there a 220nF cap on pin 18 (vUSB)? This is required for stability of the internal 3.3vUSB regulator, and could be the possible reason for the random restarts if missing? Other than that, do you have the WDT enabled? If so, try calling CLRWDT moreoften, see if that helps?
Holden VY Calais 5.7lt LS1 V8
Computer:
MB896 Pentium M Mini-ITX Motherboard, Intel Pentium M 750 1.86 GHz, 1Gb DDR2 Ram, 250GiB SATA, Xenarc 800TSV 8" VGA Monitor with touchscreen, GPS/Cellular/PCS/WiFi antenna, Bluetooth GPS, etc ,etc
Rowan is offline   Reply With Quote
Old 04-23-2007, 06:25 PM   #289
P3D4T0R's CarPC Specs
P3D4T0R's Avatar
Vehicle: 1987 GMC Jimmy
My Photos: (8)
Alright... sounds good, I think. Im looking forward to the improvements/fixes.
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (The PlowPuter)
P3D4T0R is offline   Reply With Quote
Old 04-23-2007, 06:32 PM   #290
P3D4T0R's Avatar
My Photos: (8)
Is there a 220nF cap on pin 14 (vUSB)? This is required for stability of the internal 3.3vUSB regulator, and could be the possible reason for the random restarts if missing? Other than that, do you have the WDT enabled? If so, try calling CLRWDT moreoften, see if that helps?
OK, to test this Ill use another computer running windows XP.
Sponsored Links
Old 04-23-2007, 06:38 PM   #291
My Photos: (0)
There's a 470nF cap.
I'll look into WDT.
Old 04-23-2007, 06:39 PM   #292
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Xp/Vista should be fine right now because the same problem has popped on on both OS's. So you could try, but I dont think that alone will make a difference.
Old 04-23-2007, 06:43 PM   #293
P3D4T0R's Avatar
My Photos: (8)
Your right... It hasn't.
Old 04-23-2007, 06:48 PM   #294
2k1Toaster's Avatar
My Photos: (1)
Looks like a fix is pretty much being tested now, so fret no longer.
Old 04-23-2007, 06:59 PM   #295
My Photos: (0)
WDT is disabled on the firmware I have now. I have no idea what went out on the beta boards - I didn't save the configuration because I barely made it to the post office.
Old 04-23-2007, 08:30 PM   #296
My Photos: (0)
Unresolved Bugs
Fixed Bugs
Odd habit of connecting/disconnecting
Other Improvements
I have the timed turnoff working independently for each channel... in other words, you set each channel to turn off after x number of seconds.
If you have not paid for your relay and temp sensor, you need to.
Once everyone reports in with a day or two of experience, I will send out new firmware PICs. We will provide an envelope with postage.
Old 04-24-2007, 03:10 AM   #297
2k1Toaster's Avatar
My Photos: (1)
Ok, new update to the program: http://www.fusioncontrolcentre.com/S...2024-04-07.zip
Just replace the current *.exe with this one.
Changes for 24-04-07:
* Graphs now work again
* Took off protection timer for analogue timers. Now you can update at a theoretical 1mS interval. This is getting us around 17 kilobytes a second in data transfer. Which is more than enough resolution.
* Added some program protection.
More updates will come soon.
Old 04-24-2007, 04:05 PM   #298
Vehicle: 1992 Dodge Stealth R/T Twin Turbo
My Photos: (0)
Exclamation Merry Christmas
Eh, got a package from santa in FL yesterday so i figured i would take some pics of it and share.
David
StealthRT is offline   Reply With Quote
Old 04-24-2007, 04:56 PM   #299
My Photos: (0)
We should hire you to be our photographer!
I have updated the firmware.
Firmware Version 0.2 includes:
Fix - USB disconnect/reconnect
Fix - Analog 1/2 reversed
Added - Timer function for individual digital out channels
Changed - Theoretical Maximum Refresh rate from 32mS to 1mS
Old 04-24-2007, 05:47 PM   #300
2k1Toaster's Avatar
My Photos: (1)
putting me out of a job, eh?
Sponsored Links
vB code is On
Trackbacks are Off
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 19 05-20-2008 08:05 AM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 02:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 03:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 09:52 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
